I think I fixed the problem with my Direct Port...
Old Aug 23, 2002 | 07:09 AM
JAIMECBR900's Avatar
As some of you guys know, I was having terrible problems with my direct port setup I installed a couple of weeks ago.
http://forums.maxima.org/showthread....hreadid=145729
I was writting as a follow up to that thread. The problem MAY have been resolved now when I went back and re-installed my 255 walbro pump that I took out trying to cure an overly rich problem that turned into a falling down off the line problem. With me so far?
After researching for days, I took the advice of fellow orgers and re-installed my 255 walbro pump and lowered the FP at the regulator. VOOLAH! The car now engages immidietly and pulls hard. Now, I have not done a full 1/4mi run engaged, but my butt dyno tells me it will pull all the way thru. I will slowly up the FP back to as close as possible to the desired stock levels, since I am at 25psi right now which is pretty close to the edge and don't want to run lean on the top. So far, the gauges say I'm still a little rich, but that is only on test runs of 1st/2nd gear and then shutting down. I will creep the FP up until it gets close enough to right.
I wanna really thank my boys that have been really instrumental in helping me with this puzzle: SX7R, BRIGUYMAX, SR20DEN, BAGS, NISMO2020, and 1MAX2NV. All these guys kept me from going over the edge and kept me going in the right direction with their suggestions of possible cures. I really appreciate you guys taking the time out to scratch your heads with me and figure this one out. Yall are my boys...
I am not going to try and jump up and down too much just yet, tonight's track night again, and that's going to be the real test to see if the problem is fixed. You guys wish me luck. Hopefully the guy with that dam* white civic that runs 12.6's won't show up and I'll take the title. If he shows, I may have to try and unplug his big a$$ T-70 turbo or slash his slicks to have a chance. I will let you guys know how it goes.
Once again guys, Thank you for all the help and suggestions.
Old Aug 23, 2002 | 07:21 AM
mtrai760's Avatar
'Trynna' is not a word
Congrat's on getting it running right!!!!
Old Aug 23, 2002 | 07:44 AM
sx7r's Avatar
good deal. lets see 12s.
Old Aug 23, 2002 | 07:48 AM
Ramius83
After he converts it to a 5-speed......
Old Aug 23, 2002 | 07:56 AM
That's harsh....We'll see what happens tonight. If I put some slicks on it, tweak on it a little, put a hole on the floor board from the accelerator, and maybe strap a rocket on the back....I think I can get to the 12's.
Old Aug 23, 2002 | 07:58 AM
Ramius83
Go Gadget Go.......
BTW Jaime, that was a joke earlier.....
Old Aug 23, 2002 | 09:41 AM
Bags's Avatar
VG Ridah's Biatch Hoe
good deal man.. I did not do a thing really. Just asked a bunch of questions.
really glad to know you got everything working
kick some booty at the track
Old Aug 23, 2002 | 09:47 AM
Cumalot's Avatar
Stick with the auto...for now anyway. I want to see what an auto Maxima with a direct port nitrous system can really do. 12s? Hm...I say low 13s shouldn't be a problem.
Old Aug 23, 2002 | 10:10 AM
JAY25's Avatar
I would go to the track today but I have to watch my kid!!also that track gets mighty packed!!so going early is a must!!
Old Aug 23, 2002 | 10:30 AM
SMX's Avatar
SMX
Yes!! glad to see that you found out the problem. I guess this means that I wont be able to get the fuel pump from you know.
Old Aug 23, 2002 | 11:07 AM
Ramius83, you know I'm just playing...you still my boy.
Bags, you got me to thinking which is a task all in itself.
Jay25, you know I need backup don't you?...
SMX, I may still have to downsize to the Walbro 190L which is much better than the stocker 190L, but will decide after running a couple of times with the 255 first. I'd rather be on the rich side than the lean. Will definetly let you know. You got dibs, don't worry.
Cumalot, I'm gonna stick with the auto for a while. I wanna push it to as much as she can hold and see what happens. I am seriously thinking about getting another car as a "race only" car that I can really play with. Daily driver is a challenge since you gotta factor in daily driveability into everything.
Old Aug 23, 2002 | 12:11 PM
ivolley's Avatar
13.9
13.8
13.7
13.6.................
Good luck, I will return in a month or so minus the 17s up front.
Old Aug 23, 2002 | 02:23 PM
Originally posted by ivolley
13.9
13.8
13.7
Thanks bud. Listen, I hadn't forgot about you and the pics. I think I may have messed up and when you and I looked at them on my comp at the office I may have accidentaly downloaded them onto that comp which has no burner. I went home to try and burn them for you and couldn't find any pics at all on the reader. I will try and re-retrieve them over the weekend and let you know. Worse comes to worse, I will come to your office and re-take some more. I'll let you know.
Old Aug 23, 2002 | 07:11 PM
nismo2020's Avatar
Needs non-Maxima Friends
good luck jaime.
Old Aug 24, 2002 | 01:22 AM
BriGuyMax's Avatar
Good luck Jamie...I know tuning this stuff can be a B!TCH.....
Old Aug 24, 2002 | 03:24 PM
1MAX2NV's Avatar
I just got back from the track with my current setup. Why did I mess with it when the 100 shot jets worked well. The .024 nitrous and .018 fuel is way too rich. When the bottle pressure was at 1100psi, it ran really good. When the bottle pressure was at 900psi, huge dense black smoke came out of my tail pipe and it ran like crap. I might just go back to the 100 shot. There is just way too much wheel spins in first gear to be useful.
Old Aug 24, 2002 | 08:56 PM
Hey bud, I just went to the track last night and I ran my best times yet, eventhough traction was a big issue. 13.3 @108mph and that's with 2.3 60' and a ton of wheel spin coming off the line. I've decided to go with slicks and see what I can do about traction. I know that if I can bring my 60' times back to where they were when I didn't have such massive wheel spin (2.10 or lower) the car is going to run 13 flat or better. I just know it...
As for your troubles, it's my turn to help.
Don't go back to the dry just yet. Let's try something first. It's gonna sound scary, but trust me it worked for me. If you have an adj. FPR (which you probably do) turn your FP down to 28psi. Next, take that .018 fuel jet and drop it to a .016 to start with. Keep the bottle pressure at 900-950psi all the time to be able to keep a good baseline for tuning. Do this only if you have the 255 walbro pump in and make sure and keep the bottle pressure at 900-950psi so you can have a good baseline for tuning.
Once you do that, take a test run and make sure and watch the gauges. Do a couple of runs after re-checking your settings, specially bottle pressure (to keep a good baseline) and FP (same reason). Based on the gauges on the test runs, adjust either the FP or jets accordingly. You probably don't want to run FP any further down for now. Try that and tell me what happens. BE CAREFUL AND WATCH THE GAUGES LIKE A HAWK, AT THE FIRST SIGN OF BEING LEAN---GET OUT OF IT AND TWEAK UP ON THE FUEL SIDE----.....
Old Aug 25, 2002 | 08:45 AM
Ramius83
Jaime, I have a question for you, did you buy the whole fogger kit to go direct port, or did you just buy the solenoids, fittings, nozzles, and lines? And where/how much did you buy it for, thanks Jaime.
Old Aug 25, 2002 | 04:49 PM
nismo2020's Avatar
Old Aug 25, 2002 | 05:53 PM
infinitiblast's Avatar
Imagine the look on my face..as the only other maxima I saw runs a 13.3 ....I was like ok I feel slow and I havent even run yet. I did acheive a decent run myself for 99 5spd with stillen intake. 15.26 @ 90.54 with a 2.29 60'. It was nice to meet you Jaime. I drove that other max the white one. I couldnt get it to break 15.5 kinda feel srry for the dude. Awesome run though man, nice way to represent. Now come help me put that system on my car! haha
Old Aug 25, 2002 | 10:00 PM
I had the guys at the shop order the individual parts since I already had part of the system. They were all ordered thru Barnetts speed shop downtown who ordered them from Holley. My buddy that owns Mahdavi ordered it all for me and we installed it over at his place.
You already have half the stuff. You will need a fuel solenoid, hard lines, bender, 6 fogger nozzles, jets, 2 distribution blocks, and assorted fittings to convert it over. The scariest part is tapping the intake plenum. I personally had that done by the pros.
rnb754
Sep 14, 2015 11:39 PM
mpbclutch33
Sep 8, 2015 06:21 PM
slowlifer
Sep 8, 2015 05:53 AM
Maxima30
Sep 7, 2015 06:13 PM
