Maintenance...
Old Sep 1, 2002 | 02:06 PM
P()()RB@Y's Avatar
Maintenance...
Is there something that goes out on Max's more than other cars that I might need to check for?
In the next couple weeks I was going to check out a bunch of things to make sure everything is in order.
Spark Plugs - NGK coppers
Wires - ?
Fuel filter - does anyone make a performance fuel filter?
Compression
Anything else?
Old Sep 1, 2002 | 04:05 PM
iwannabmw's Avatar
Re: Maintenance...
Wires - ?
Compression
Anything else?
On the 4th gens, the plugs should be NGK Platinums, there are no wires per se. Use the 300ZX fuel filter instead. Compression is 10:1
Common problems, starters and alternators, knock and O2 sensors, and vent control valves mostly. Some of the 5 speeds have bearing issues. On the whole, major mechanical issues don't crop up on these cars if well maintained, it's mostly nuisance stuff.
Old Sep 1, 2002 | 04:58 PM
libo74's Avatar
Producto Colombiano
Re: Re: Maintenance...
use a particular year 300zx fuel filter? or will any year do?
thanks
Old Sep 1, 2002 | 07:49 PM
iwannabmw's Avatar
Re: Re: Re: Maintenance...
thanks
They're all the same.
Old Sep 1, 2002 | 07:51 PM
Sprint's Avatar
you don't have to use Platinum Plugs.. thats only if you are lazy and dont' feel like changing them every 30 k miles.. NGK Copper are better than Plats.. and i highly reccomend them over Plats.. they are way cheaper and give better performance..
Old Sep 1, 2002 | 07:56 PM
iwannabmw's Avatar
I'm lazy, I spend too much time with the car as it is
Old Sep 2, 2002 | 07:35 AM
libo74's Avatar
Producto Colombiano
Re: Re: Re: Re: Maintenance...
thanks.
HiQMax
Aug 12, 2012 09:13 PM
mahanddeem
Oct 9, 2010 05:17 PM
Oolatec
Mar 23, 2010 05:56 PM
tavarish
Mar 7, 2005 03:05 PM
