ProFlow Design bored out throttle body <pics)
Old 09-05-2002, 11:15 PM
Permanent Maxima.org Resident
Confused's Avatar
They were able to get a little over 3mm, put a shorter shaft in and cut in on the edges... proflow is on the left and oem is on the right. Enjoy!
http://www.confusedmax.com/tb/
Confused is offline
Old 09-05-2002, 11:18 PM
Nismo's Avatar
link is fudged
Nismo is offline
Old 09-05-2002, 11:24 PM
Confused's Avatar
works here... anyone else see it?
Confused is offline
Old 09-05-2002, 11:26 PM
TurDz's Avatar
I see it. VERY NICE! Will you get dynos on this?
I also assume this is only benificial to guys with boost?
TurDz is offline
Old 09-05-2002, 11:27 PM
ny96max's Avatar
i see it perfectly fine Brett!
Ant
ny96max is offline
Old 09-05-2002, 11:29 PM
Nismo's Avatar
guess my computer is fudged
Nismo is offline
Old 09-06-2002, 03:39 AM
NickStam's Avatar
i don't see it
NickStam is offline
Old 09-06-2002, 03:54 AM
i SeE what you did therE
redmaxpa007's Avatar
3mm? how much more gain do you expect?
redmaxpa007 is offline
Old 09-06-2002, 04:09 AM
mingo's Avatar
looks real nice.. what's tha thing that is plugged up on the tb on the left.. is this made for maxima?
mingo is offline
Old 09-06-2002, 04:45 AM
Eagles Fan 4 Lyfe
Chris91SE's Avatar
you'd still be slow
Chris91SE is offline
Old 09-06-2002, 05:59 AM
Confused's Avatar
no dyno on just the t/b...sorry..
its part of the every little bit helps, well i have it off anyway school.. lol
throttle response should be crisper
ok for n/a? i'll let you guys debate that..lol.
oh.. that thing in the top left is a custom made throttle body opener... or a zip tie.
Confused is offline
Old 09-06-2002, 06:19 AM
Originally posted by Chris91SE
you'd still be slow
no cracker, i do not want one..
i wanted to know what 3mm difference on a throttle body would do?? thats all..
Old 09-06-2002, 06:38 AM
Rice Boy in Denial =)
Y2KevSE's Avatar
Will this make me run 11's in the 1/4 mile?
Nice!
Y2KevSE is offline
Old 09-06-2002, 07:48 AM
Lime's Avatar
kewlll. I doubt it would really help n/a unless we add cams....
Lime is offline
Old 09-06-2002, 07:53 AM
'Trynna' is not a word
mtrai760's Avatar
Sweet!
mtrai760 is offline
Old 09-06-2002, 07:58 AM
HulaMAX's Avatar
Looks nice!
HulaMAX is offline
Old 09-06-2002, 08:20 AM
Ad·min·is·tra·tor
DanNY's Avatar
safe to assume you're going to port match the intake manifold too right?
do they calibrate the TPS or would u have to do it..or do they instruct u to take off the TPS before shipping it in?
DanNY is offline
Old 09-06-2002, 08:24 AM
matt calder's Avatar
How much?
matt calder is offline
Old 09-06-2002, 08:35 AM
deezo's Avatar
Looks clean .
deezo is offline
Old 09-06-2002, 09:19 AM
Soon2BMaxed's Avatar
how much was it?
Soon2BMaxed is offline
Old 09-06-2002, 11:52 AM
Confused's Avatar
yes but i'll wait for more skilled hands then myself. they don't calibrate the tps, my used one didn't have a sensor on it so it wasn't sent either. Any helpful tips Dan?
Price is normally $190 but the group buy got 20% off.
Confused is offline
Old 09-06-2002, 12:18 PM
Ad·min·is·tra·tor
DanNY's Avatar
hook up the volt meter on the bad boy. u want to have the voltage at a certain range during idle. it's a PITA to do..that's why i asked if they help u out. check a FSM for the voltage range. it's almost like adjusting timing..but takes a lighter touch.
where u get this group buy from?
DanNY is offline
Old 09-06-2002, 02:16 PM
96sleeper's Avatar
What is the extra nipple on the new TB? I ordered one that is supposedly from a 98 I30 and it doesn't have that extra one on the bottom, I am not sure about on my stock 96 one, but I think it does. On the one I got, there are 2 coolant lines, and one vacuum line that is plugged with a rubber stopper.
96sleeper is offline
Old 09-06-2002, 05:02 PM
MardiGrasMax's Avatar
its shiney, like mirror!
MardiGrasMax is offline
Old 09-06-2002, 05:13 PM
Keven97SE
I think the bored out TB is from a 99 Maxima. I noticed that extra nipple on those years. It's capped so it's not in use on the 99's, just like in these pics.
Old 09-06-2002, 10:39 PM
1MAX2NV's Avatar
Woh..that throttle plate is like super polished. Is it still metal? because on the second pic it looks like plastic.
1MAX2NV is offline
Old 09-06-2002, 10:43 PM
1MAX2NV's Avatar
Keven is right. The one on the left looks just like mine. I have a spare 1999 with a busted TPS. I believe the Auto TB and the manual TB are different. Since I don't have a manual TB to compare with, I have no idea the difference are.
1MAX2NV is offline
Old 09-06-2002, 10:59 PM
1MAX2NV's Avatar
I take that back. The one on the left does not look like mine.
Here is a throttle body from a 1999 Auto.
http://photos.imageevent.com/1max2nv...e/DCP01295.JPG
http://photos.imageevent.com/1max2nv...e/DCP01296.JPG
1MAX2NV is offline
Old 09-09-2002, 11:09 AM
96sleeper's Avatar
If anyone else would like to participate in this group deal, Jim will give 10% for two, or 20% for three or more. I am thinking about doing this, so if anyone is intertested email me.
Old 09-16-2002, 08:30 AM
Deac's Avatar
Re: ProFlow Design bored out throttle body <pics)
I know someone used a Pathfinder Throttle body and modded it into a 4th Gen. From what I undersatnd (I could be wrong) this is not a very difficult mod to have even if you have to fabricate a throttle body or use one from a different car. So we know you can "bore out" the stock one, we know you can use the pathfinder one on a max...any body evr check into use a G35, 300ZX, or even 350Z throttle body on a max? Would be interesting to know if even had a chance at working!?
Deac
Deac is offline
Old 09-16-2002, 08:42 AM
VG Ridah's Biatch Hoe
Bags's Avatar
Re: Re: ProFlow Design bored out throttle body <pics)
Deac
mardigras did it
Bags is offline
220k+ A32
09-23-2015 03:38 PM
bumpypickle
09-20-2015 08:22 AM
97_GXE
09-15-2015 06:47 AM
followthadollar
09-13-2015 09:55 AM
Maxboy23
09-09-2015 10:37 AM
Quick Reply: ProFlow Design bored out throttle body <pics)
