Tightening AC belt to rid squeeling
Old Oct 15, 2002 | 08:28 AM
gjabo178's Avatar
Hello,
Dam squeeling is stressing me out...
Can I tighten the belt from the engine bay or do I need to lift
the car??
Old Oct 15, 2002 | 08:41 AM
Lime's Avatar
can be done from above. I think the tensioner is like a 14mm, but I forget.
Old Oct 15, 2002 | 08:55 AM
Synki's Avatar
The acc. belts can be adjusted from top and bottom. Usually whenthe belt squeeks, it is time to replace it.
Old Oct 15, 2002 | 10:34 AM
gjabo178's Avatar
it was replace three weeks ago
Old Oct 15, 2002 | 11:12 AM
BlackCat's Avatar
RIP '98 Maxima SE
Yep its 14mm. Turn clockwise to tighten, counterclockwise to loosen.
Old Oct 15, 2002 | 11:30 AM
gjabo178's Avatar
Thanks much
Old Oct 15, 2002 | 11:31 AM
Lime's Avatar
Generally new belts tend to loosen up in the first week or so; this is absolutely normal.
Old Oct 15, 2002 | 12:32 PM
Larry's Avatar
If it's the ac/alternator belt and it's like my 2K2 then you have to loosen the center nut on the tensioner pulley and then turn the 14mm adjuster bolt clockwise to tighten the belt. Don't over do it.
Old Oct 16, 2002 | 11:48 AM
gjabo178's Avatar
What, like a full turn????
markevans999
Oct 25, 2015 08:27 AM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
homewrecker
Sep 23, 2015 03:41 AM
