Exhaust difference 5-speed vs. auto??
Old Oct 17, 2002 | 08:51 PM
purmax's Avatar
Is there any difference in the tone of a Maxima 5-speed w/ exhaust and an auto with same set-up, because when i rev my car it gets loud then quiets out. and other peoples (non-maxima) will rev and it stays loud, or could it be the muffler (no flames it's an arospeed loudpipe)??? just wonderin thanx
Old Oct 17, 2002 | 09:22 PM
Y2KSESteve's Avatar
Re: Exhaust difference 5-speed vs. auto??
Would be very small difference if any at all.
Old Oct 18, 2002 | 01:44 AM
Nismo's Avatar
are those "other cars" 4 bangers?
Old Oct 18, 2002 | 03:09 PM
purmax's Avatar
Re: Re: Exhaust difference 5-speed vs. auto??
most are with the occasional V6 accord thrown in
Old Oct 18, 2002 | 08:30 PM
Craig Mack's Avatar
All YOUR grammer belong to me
I'm not sure I understand your question but the difference in exhaust tone between an auto and 5spd is due to the gearing. With an auto it locks out in the highest gear it can to keep your cruising RPMs low. This keeps your exhaust note deep. Generally with a 5spd you can put it in 5th and get as deep or deeper tone (depending on the RPMs). It's a different story on the highway though. With my auto, I was cruising at around 2300 rpms at 70mph. With my 5spd it's at around 3,000, so my exhaust is louder and ricier.
I also notice that at certain RPMs the exhaust will get really quiet and that's where I try to settle into when I'm cruising. This is what i've noticed:
1000-2000rpms is deep and throaty
2100-2250rpms it gets raspy and higher pitched.
2300-2700rpms it gets very quiet
2800-3100rpms it gets once again raspy and high pitched.
3200-3700rpms it gets quiet again
I usually try to find the sweet (quiet) spots in my gearing and cruise there. Otherwise the noise gets on my nerves. I also hate the ricey notes I get when I downshift into the "raspy RPM zone".
Old Oct 18, 2002 | 10:40 PM
Dev's Avatar
Dev
i think that the tone of the sound coming out of the exhaust would be about the same. but since the rpm's are different most of the time, u'd probably hear a different tone. like when coming to a stop, a 5spd would make a lot of noise from the exhaust (if in gear, not neutral) whereas an automatic doesn't make any noise at all.
personally i like the sound of an exhaust on a 5spd a lot more than an auto cause 1) ur in control of the gears/sound and 2) under NORMAL driving, an auto w/exhaust makes a high tone in 1st, gets lower in 2nd, lower in 3rd, etc. and each gear has a monotone sound...where a 5spd has different tones in each gear, kind of low at the beginning, then fades out in higher rpms.
Old Oct 19, 2002 | 04:30 AM
Ghost face Max's Avatar
I don't think there will be a big difference in sound..
hot04
Sep 18, 2015 06:14 AM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
