AWD SUCKS from a roll: Episode 249,671
Old Oct 20, 2002 | 08:51 PM
  #41
Maxhawk's Avatar
Re: Re: Re: Re: Good "run" Steve....
Originally posted by IceY2K1
[B]
What are the typical 1/4-mile times for both 6spd and tiptronic STOCK? What are the best times STOCK? Just curious, because I may be looking to buy one someday.
You can find a short list of 1/4 mile times here: http://www.s4biturbo.com/timeslips.html
Dynopack 4WD dynos seem to be the most consistent right?
Sorry, don't know much about 4wd dyno brands. You'll need to search Audiworld to see which ones come up.
Who's "Stage 3" is that?
That would be AWE, who uses GIAC software. APR has a similar setup with similar numbers. Most of the K04 software is still in beta, and there's still lots of debate about what makes the perfect Stage 3 kit. I'm gonna wait it out until there's more data about whose is fastest and most reliable.
Old Oct 20, 2002 | 10:10 PM
  #42
Synki's Avatar
If you think a chipped S4 with a few minor bolt-ons won't pull to 140-160 like nothing, obviously you never owned one.
Go to audiworld and search under the S4 forum. You will be amazed at how fast they pull at that kind of speed. This is why they are highway monsters. You may also want to check out the Gumball videos.
A properly launched S4 with at least a Stage 2 should be able to muster 1.8 60fts.
Old Oct 21, 2002 | 06:24 AM
  #43
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Hmm...well after all the discussion, maybe I really did only pull on an automagic.
All I know is this. A stock WRX 5spd will pull about 165-168 whp on a Dynapack AWD dyno and they weigh 3085 lb. They also trap in the low-90's but with a much better ET (AWD launch) than me. Now compare that to my 160 whp stock 5spd Maxima and slightly less weight and you have a very good rolling race. I've run two stock/nearly stock WRX 5spds on the street. One I was dead even with from 30-80. The other I pulled a few cars on and BEAT him from 20-80, but only because the idiot couldn't shift worth a crap and completely blew past his 2-3 upshift point and bogged it up top. Mark that one down as sh!tty driver
But from this experience, I think a Dynapack dyno is pretty representative of the actual power that gets to the wheels. That said, if a stock S4 6spd dynos on a Dynapack at 188-190 whp, then that matches my stock power to weight ratio and I *COULD* have pulled on a 6spd. But who knows...
Like I said, maybe they really are much faster stock but the guy just couldn't shift. With peak power at 6000rpm on the S4, if you take that puppy all the way up to redline (7000) before shifting, you're simply not going to get the best performance. Same with a VQ30DE (more redline than lung capacity), only I know when to shift. Maybe this guy didn't.
But if S4 6spds really do pull high-90 traps stock, then there are one of two possibilities. They are very underrated on their stock power (from seeing the dynos, I sorta doubt this). The other possibility is that they have hella GOOD and tight gearing. From looking at the ratios, I think this is much more likely. A high-90 trap from a 250HP 3600lb AWD car is an incredible feat.
PS...the new 04 S4 is going to have a 4.2L NA V8, not a bi-turbo anymore.
Old Oct 21, 2002 | 06:40 AM
  #44
AntGVR4's Avatar
Re: AWD SUCKS from a roll: Episode 249,671
Originally posted by SteVTEC
AWD is a ton heavier, and has much more drivetrain loss, which is BAD for performance once you're already rolling.
I am guessing that you have never driven a high HP FWD car. By high hp I mean over 300 to the wheels. IF you have you would know how much it sucks and you would appreciate AWD more. I drove a FWD car that only put down 320 to the wheels and it spun 1st, 2nd, 3rd and finally started grabbing top of third, NOT FUN. Even from a roll, the turbo'd Si I was driving started spinning from a 3rd gear roll once it hit full boost. Hell my AWD car will spin 1st once it hit's full boost.
I'm not doubting your story at all, in fact good kill.
Ant
Old Oct 21, 2002 | 06:45 AM
  #45
SteVTEC's Avatar
LOL, I *do* understand the limits of the FWD platform But with my whole 160 whp and 3000 lb curb weight, I'm not even close to hitting that limit yet. No doubt I would prefer RWD to FWD, or even AWD if I had a real monster, but I don't.
I understand the benefits of AWD whenever it's rainy out, or I want to launch really hard off the line (when rainy ).
But like I said, rolling races, all AWD does is suck power and add weight.
Old Oct 21, 2002 | 06:55 AM
  #46
AntGVR4's Avatar
Right.
It does suck power and add weight. Still when you are running high HP applications it is either go with AWD and lose VERY LITTLE power and add some weight or just spin your tires through 3 out of 5 gears.
Drive a turbo maxima and see how much fun it is, I hear Sprintmax has one?
Ant
Old Oct 21, 2002 | 06:58 AM
  #47
SteVTEC's Avatar
Note that the thread title is "AWD SUCKS from a roll"
Not "AWD SUCKS PERIOD!" hehe
I see your points, though
Old Oct 21, 2002 | 07:00 AM
  #48
Y2KevSE's Avatar
Rice Boy in Denial =)
Go Steve!
  #49
Synki's Avatar
Steve, either way I still say good job!
I just don't appreciate people claiming things about cars when they have never owned it or even raced it. I like to look at things at both ways and since I have owned both cars, I can. Though I only owned my S4 for a short time, I savored every minute of it.
Ant-Lunch?
Old Oct 21, 2002 | 07:05 AM
  #50
Synki's Avatar
Oh yea, though this thread is about AWD from a roll, I do agree my WRX (or most AWD vehicles) isn't what I would call spectacular from a roll. When you take the launch away from a AWD (the biggest advantage), that is like stealing someones coat from them in the winter while its snowing and letting them freeze.
This is why more HP is required.
Old Oct 21, 2002 | 07:08 AM
  #51
SteVTEC's Avatar
Well that's one way of putting it. But I would not even pretend to think I could take a WRX/S4 from a stop, either. And if it was wet out, they'd be passing the next block before I had even feathered myself up to 2nd gear
But I agree that if you're planning on taking your car to INSANE power levels, RWD or AWD are *much* better platforms to work with than FWD.
Old Oct 21, 2002 | 07:33 AM
  #52
AntGVR4's Avatar
We'll see about that.
Kevin is that turbo on yet ? timeslips ?
Go Anthony
Ant
Old Oct 21, 2002 | 07:38 AM
  #53
Synki's Avatar
Keving, you have joined the dark side of loud whining hair dryers.
Old Oct 21, 2002 | 07:45 AM
  #54
Sprint's Avatar
Ant
I heard that too.. althought someone in the FS forum just told me i was lying about it because i make up stories on the org to look friends
guitarman
Sep 19, 2015 11:52 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
maximusrising
Sep 4, 2015 06:31 PM
paulpearl
Sep 2, 2015 07:50 AM
