Had my mechanic tighten my belts to stop squealing..
Old Dec 7, 2002 | 10:25 PM
BrianV's Avatar
I had my mechanic tighten my belt to stop the cold weather squealing. I just drove like 100 miles (just cruised, no hard driving). When I got home the SC seemed to be making a bit of a scratching noise (I can't explain it).
I did a search and couldn't really find anyone who said they had a sound like this. I was wondering if the belt being too tight could cause that noise, or whether my bearing on the SC finally went to crap. The sound wasn't that loud I could only hear it with the hood open.
What do you think? Also, what size socket do I need to loosen the belt?
Old Dec 8, 2002 | 05:40 AM
MardiGrasMax's Avatar
Re: Had my mechanic tighten my belts to stop squealing..
14mm
No more deflection the ~70 degrees when twisting the cranlk to AC belt langth.
Old Dec 8, 2002 | 05:52 AM
Sprint's Avatar
you should have watched so you could do it yourself next time
Old Dec 8, 2002 | 05:59 AM
Frank Fontaine's Avatar
I've always had the problem since new. It went away when I got the belts adjusted under warranty, but came back. Then eventually I had the belts replaced and it went away, only to come back. Now I figure it'll go away again when I get the alternator replaced under warranty. It's an annoyance, much like the sound the fan on my power supply of my Dell just started making this morning!! Warranty time....
Old Dec 8, 2002 | 09:51 AM
BrianV's Avatar
Well I checked the deflection and it's probably like 85 degrees (almost 90). Also I didn't hear it when I started it up but cold it idles a little higher. I chekced the inside of the SC (removed filter) and visually everything looked like new.
The SC is pretty loud as it's a v1, maybe I was hearing things in my head yesterday, I'll have to check it again after it gets warmed up and taken for a drive.
PS - also checked oil line, so I know that's no a problem.
This V1 has some miles on it but hasn't had any problems I really don't want to have to send it in, but if I do $400 isn't too bad, it's just the hassle of getting it off and not having a car for a long time.
Old Dec 8, 2002 | 12:45 PM
Kenneth's Avatar
OG :)
maybe he broke your tensioner
Old Dec 9, 2002 | 01:39 PM
OgreDave's Avatar
Re: Re: Had my mechanic tighten my belts to stop squealing..
happened to me when i had my altenator replaced .. idiots.
btw, is 14mm the size of the actual nut on the tensioner, or the adjustment 'nut' ? gotta adjust mine too.
Old Dec 9, 2002 | 02:34 PM
BlackCat's Avatar
RIP '98 Maxima SE
I know that the V1 sounds way louder than the V2 but have you heard what mine sounded like when it was going bad?
http://www.cyberhub.net/scsound.wav
Old Dec 9, 2002 | 02:50 PM
BrianV's Avatar
my lord then my sc is certainly not bad, actually I haven't heard it, and it sounds fine still. I think I was just tripping out. Damn that sounded awful.
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
