300ZX Brakes Install, with Pics.......
Old Jan 14, 2003 | 05:42 AM
  #41
Sprint's Avatar
Re: Re: Re: Re: 300ZX Brakes Install, with Pics.......
Originally posted by Aaron95SE
Then with the width and offset of the rx7 wheel they will be pushed out past the wheelwell
Aaron
Old Jan 14, 2003 | 05:51 AM
  #42
Aaron's Avatar
Langley AFB Sux
Re: Re: Re: Re: Re: 300ZX Brakes Install, with Pics.......
Originally posted by SprintMax
Excatly, Sprint.....................a look I desire not to have on my max.
Old Jan 14, 2003 | 06:09 AM
  #43
redmaxpa007's Avatar
i SeE what you did therE
Re: Re: Re: Re: Re: Re: 300ZX Brakes Install, with Pics.......
yes you do.. you told me so on AIM the other night...
Old Jan 14, 2003 | 06:28 AM
  #44
Aaron's Avatar
Langley AFB Sux
Re: Re: Re: Re: Re: Re: Re: 300ZX Brakes Install, with Pics.......
Old Jan 14, 2003 | 06:31 AM
  #45
Re: Re: Re: Re: Re: Re: Re: Re: 300ZX Brakes Install, with Pics.......
you and sprite are both PMS'n this morning.. sheesh
Old Jan 14, 2003 | 06:33 AM
  #46
Aaron's Avatar
Langley AFB Sux
Re: Re: Re: Re: Re: Re: Re: Re: Re: 300ZX Brakes Install, with Pics.......
I woke up this morning and I'm still not rich.........wtf
Old Jan 14, 2003 | 06:55 AM
  #47
Sprint's Avatar
Old Jan 14, 2003 | 07:19 AM
  #48
kramerica72's Avatar
Click on the links on my post refering to this swap. Its as Ramius stated. The only difference between the 26 and 30 mm calipers is the rotor thickness. The overall width of the caliper itself is the same. The 4mm difference is in the rotor channel..........not the actual width of the caliper.
The link with Asad's caliper write up shows this clearly.
Here.......
http://www.princeton.edu/~asad/zbrakes/images/4.jpg
Aaron
I have a call into my local parts store to have them pull the calipers and compare them. They do look different on this pic, however. If you look at the 26mm where it has "90" written in yellow, it appears to be at least a few mm's narrower.
http://www.princeton.edu/~asad/zbrakes/pages/2.htm
Old Jan 14, 2003 | 07:42 AM
  #49
Aaron's Avatar
Langley AFB Sux
Hmmmm so maybe a smaller spacer.....
Old Jan 14, 2003 | 03:51 PM
  #50
superloon's Avatar
Very nice mod!
Looks great Ramius! Sounds like they do the job pretty good too. Just had a lil' suggestion: Next time you pull the wheels, take a file (or disc sander) and shave the face of the Nissan logos--kinda like this:
Just a thought
theLoon
Old Jan 14, 2003 | 09:23 PM
  #51
Ramius83
Re: Very nice mod!
Just a thought
theLoon
Yeah yeah, I know. When I had the calipers off, I actually did try to paint the NISSAN white, but the white would not stick to the powdercoating. When I have a chance next time, I am gonna just sand them down a little with a file and leave it at that.....Thanks for the suggestion....
Old Jan 15, 2003 | 03:51 AM
  #52
Aaron's Avatar
Langley AFB Sux
Re: Re: Very nice mod!
Haha! Those look like 120$ Irotors Same as I purchased
Old Jan 16, 2003 | 01:17 PM
  #53
Lordrandall's Avatar
Hmmm I tore apart my whole front brake setup.....ZX Calipers, Rotors.......the RX7 wheel will need at least 20 mm spacers to clear on my 4th Gen. When holding the rx7 wheel up in position to clear the caliper all that was visible of the stud was the end there was not even one thread showing on the stud....and that was holding in as close to the caliper as possible.
On my setup, with the width and offset of that wheel if I went with spacers that size the wheel would stick out...........not good
Perhaps the 3rd gen geometry is a bit different.....fender wise.....etc.
Well the 4th is designed to work with higher offset wheels than the 3rd gen, and that might make the front caliper clearance very poor with the RX7 wheels. I've got 20mm adaptors for my rear RX7 rims, and they look great. But then again, the perfect offset for a 3rd gen with 8" wide wheels is about 30mm.
I know on a 4th gen, you don't need a front spacer at all, and maybe a 5mm rear. I've got 5mm front, and 20mm rear.
I'll let you know if I ever get a shaved Z rotor to test on.....
Mingo?
Old Jan 18, 2003 | 09:49 AM
  #54
CandiMan's Avatar
Say Candyman 5 times
I got a question
How important is it to know the production date of the donor car that your Z32 calipers came from? From searching for Z rotors there seems to be several different production dates to choose from, one particular year could have two different production dates. For those who purchase there calipers over the net, or from a friend of a friend and they were only given "These calipers came of a 199_ Z" will these guys have a problem buying rotors. Does one rotor fit them all regardless of year? Due to the 26mm and 30mm calipers are the only difference in rotors the thickness? If you got a 26mm caliper is it best to search for rotors for the 30mm caliper? I was lucky enough to take a peek at the VIN tag when I pick up my calipers at the bone yard, 6/89
After finding my answer from another alert member, I'll just update instead of deleting my post.
280mm x 26mm were used on n/a 2/89? - 7/89
280mm x 30mm were used on all others application
Or something like that
Thanks, MIKE
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
