JWT ECU + MEVI = Jaw on floor
Old 03-20-2003 | 06:08 AM
  #41
Sprint's Avatar
Originally posted by Anachronism
VI - ~$550
Old 03-20-2003 | 06:27 AM
  #42
Anachronism's Avatar
Originally posted by SprintMax
http://forums.maxima.org/showthread....hreadid=151928
http://forums.maxima.org/showthread....hreadid=144870
Has the price changed?
Old 03-20-2003 | 06:28 AM
  #43
Sprint's Avatar
Old 03-20-2003 | 07:05 AM
  #44
ZuMBLe's Avatar
Any drawbacks besides the CEL?
STFU b!tch.. once again you are talking out your ***..
you can use a 96 ECU in a 97
Old 03-20-2003 | 07:22 AM
  #45
Sprint's Avatar
mine was on since i cut my wire so i don't mind the yellow light
Old 03-20-2003 | 07:38 AM
  #46
ZuMBLe's Avatar
So what happens if you actually have engine problems? Kinda like the boy who cried wolf huh? Maybe you can wire up a switch to the CEL. Have the light off during normal use. Then flip the switch on when you want to check ECU codes? I want the JWT ECU for the added power. But I could spend the money on a nitrous kit and have more power. But the ECU will give me power all the time and compliment my VI. Decisions.
sprint: I did a search and read that you were inquiring about the JWT NOS ECU. 900?? If you get the regular JWT ECU, no more nitrous for you.
ZuM
Old 03-20-2003 | 07:52 AM
  #47
Sprint's Avatar
ZuM
are you sure about that?
Old 03-20-2003 | 07:55 AM
  #48
ZuMBLe's Avatar
I always thought the advanced timing of the JWT ECU + Nitrous was a no no. Am I wrong?
Old 03-20-2003 | 08:12 AM
  #49
Sprint's Avatar
Advanced Timing on a high compression motor
Old 03-20-2003 | 08:22 AM
  #50
ZuMBLe's Avatar
I thought the JWT ecu was optimized for NA use.
Old 03-20-2003 | 08:34 AM
  #51
ZuMBLe's Avatar
I just bought a 96 ECU off ebay. What have I done!??
Old 03-20-2003 | 08:47 AM
  #52
Sprint's Avatar
if you have a JWT ECU you can have them add the NOS module and you won't need an RPM Switch.. actually the JWT ECU / NOS is the safest thing out there
Old 03-20-2003 | 08:52 AM
  #53
ZuMBLe's Avatar
Yeah, but that's more $$! Didn't you say the ECU with the daughterboard is 900 dollars? Well, either way, I got the 96 ECU for a good price. I guess if I decide not to get the ECU modded, I can always just sell it to a org member.
Old 03-20-2003 | 09:06 AM
  #54
Dave B's Avatar
Not DAVEB the parts guy
JWT's nitrous ECU is a two stage unit. You can select between the nitrous program (timing retard, richened A/F) and the NA program (advanced timing, lead A/F) via a switch.
IMO, the JWT nitrous program is ideal and worth the money. The setup is idiot proof and the ECU regulates the nitrous. For $1800 (ECU, complete nitrous kit), I think it's a bargin.
Dave
Old 03-20-2003 | 09:07 AM
  #55
Sprint's Avatar
Programming and NOS addition is $900.. check cattman site for specific details
Old 03-20-2003 | 09:46 AM
  #56
MardiGrasMax's Avatar
Keep this in mind, if you want to run more than a ~65-75hp shot you need to get larger injectors using the JWT system because its a dry kit, but the fuel pressure stays at ~43psi, the injectors just open a longer time.
So add injectors to that cost if you want REAL power.
Old 03-20-2003 | 01:43 PM
  #57
Smithdogg1's Avatar
Sounds great! It is amazing that you have the fastest N/A maxima and only have an intake, y-pipe, and MEVI. And you ran a 14.7 stock in your max. You must be one hell of a driver! It sounds like you should be even deeper in the 13's with the ECU.
Mahmuth
08-16-2024 08:23 PM
litch
123
01-04-2024 07:01 PM
gigabyte
01-06-2017 06:05 PM
uttadms31
09-30-2015 05:24 AM
salty318
09-29-2015 01:21 PM
Quick Reply: JWT ECU + MEVI = Jaw on floor
