Please help! spark plug broke in half
Old Jun 1, 2003 | 01:42 PM
danman's Avatar
Hi gang, I have a 93' villager that has a nissan engine in it. I was changing the plugs and on one of them it snaped in half including the hex.
The van was just bought 2 weeks ago and I guess the dumb owner before me did'nt change the plugs for 2 or 3 years, plug were very worn.
I called the dealer and they want to remove the head costing $1200
Does anyone have any experiance with this?
Thanks.
Old Jun 1, 2003 | 03:50 PM
Maxman2000's Avatar
I'd go with replaceing the heads. But I'd first take off the head and get the plug drilled out with a bit slightly smaller than the hole and then use another plug to clean out the threads. If you understand what I'm sayin. But if your not experienced with engines the I guess the only way to go is new head.
Old Jun 2, 2003 | 08:57 PM
danman's Avatar
Hi gang, I got that P.O.S out! I bought a #5 snap on screw extractor and liquid wrench.
This is what I have found out about the dealers=crooks! No need to remove the cyl head.
Well thanks for everybodys help.
Old Jun 3, 2003 | 07:46 AM
Stephen Max's Avatar
Good for you! Now, the question is, did you leave behind any little bits and pieces in the combustion chamber? That's probably why the dealer wanted to remove the head, they didn't want to be liable for any collateral damage caused by the plug removal process.
Old Jun 3, 2003 | 09:10 AM
danman's Avatar
No nothing left behind, plug came off clean. The darn thing was siezed, had to use a lot of torque to get it off.
Heres a tip for you who change your plugs use anti-seize compound or what I do is apply a thin layer of clean engine oil to the plug threads.
Old Jun 3, 2003 | 09:13 AM
stjohnr's Avatar
Where did you get the tool and how much?
john
Old Jun 3, 2003 | 09:18 AM
95emeraldgxe's Avatar
what is liquid wrench actually??
Old Jun 3, 2003 | 09:22 AM
LatinMax's Avatar
a thin coat of oil will actually cause the plug to sieze up in there.
ALWAYS use anti-sieze never oil.
Old Jun 3, 2003 | 03:02 PM
danman's Avatar
I bought it off of a Snap-on Tool truck in my town, the #5 screw extractor part #ex-5 was $5.70cnd and a square 11/32 socket $17.10cnd
Snap-on makes very high end tools like Mac tools.
It's a penetrating solvent that loosens rusted nuts, bolts, and parts.
I was told that move-it was one of the best penetrants to use but I'm sure that they all do the same job. (don't use wd-40)
"a thin coat of oil will actually cause the plug to sieze up in there. ALWAYS use anti-sieze never oil."
For the past 16 years I have been applying a thin coat of clean engine oil to the spark plug threads when changing them with no problems at all, never has it siezed.
This is one of the best mechanics tip I have been told.
Old Jun 3, 2003 | 03:28 PM
LatinMax's Avatar
I understand. I have also heard from lots of mechanics that is what to do. But as a ex-aircraft mechaninc of 10+ years that is not allowed on aircraft plugs...anti-sieze is the only thing that is allowed.
Cars may be a little different, but I figure the AC point of view is better.
Just my opinion. All I use is anti-sieze, nothing else.
Old Jun 3, 2003 | 03:34 PM
Jeff92se's Avatar
I'm needing a caw
Oil might work but that shiney silver anti-seize stuff is the bomb! I remember putting some on my platimun plugs. Then at the 60,000 mile change out, the plugs came out easy. It's great stuff. Avoid getting on your clothes and fingers though.
Old Jun 3, 2003 | 03:38 PM
thanks, great advice and thanks for the answer
Old Jun 3, 2003 | 03:53 PM
chisam14
Nov 6, 2018 08:56 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
