Jet Vforce Anyone? *merged*
Old Jul 14, 2003 | 05:02 PM
96white's Avatar
Jet Vforce Anyone ??
I was talking with Thurznite( member on forum ), and he told me that since us 97 and above have no ECU like JWT or GFORCE to try Jets Vforce. Its a "piggy back" rather then the traditional swap ECU. I just want to know if anyone has tried it or is using it right now, and what HP gains they got.
Pic :
http://www.jetchip.com/images/vforce225.jpg
Description : The JET V-Force Power Control Modules (PCM) uses the same computer tuning technology found in JET's popular domestic tuning products. A 20Mhz RISC microprocessor optimizes the ignition spark advance and recalibrates the fuel map for optimum horsepower and acceleration.
Modified Ignition Curve
Recalibrated Air/Fuel Ratio for Maximum Performance
Improved 1/4 Mile E.T's
LED Read Out
On/Off Override Switch
Anyone that can give me info or help would be great.
Thanks !!!!
Old Jul 14, 2003 | 06:32 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
concensus on most car forums is that most of Jet's "import" products are caca! but to each his own. that thing looks like an 8-track player. I bet the ignition curve modifcations don't even work on DIS/multi-coil vehicles??
Old Jul 14, 2003 | 06:34 PM
96white's Avatar
Can someone tell me how to get a JWT OR GFORCE ECU in my 97GXE 5spd !!?
Old Jul 14, 2003 | 06:37 PM
Nealoc187's Avatar
SLOW
Order one? JWT Avalon and Cattman sell JWTs. Not sure if you can get a new G-force anymore, may have to get it used.
Old Jul 14, 2003 | 06:38 PM
96white's Avatar
or Can someone tell me how to get a JWT OR GFORCE ECU in my 97GXE 5spd !!?
Old Jul 14, 2003 | 06:39 PM
96white's Avatar
How can I order one if they dont sell one for a 97 5spd?
Old Jul 14, 2003 | 06:52 PM
sryth's Avatar
You, supposedly, can use a JWT 95/96 ECU in a 97 as long as the model/tranny match. No experience on this, but it's supposed to work. I've heard that on some cars, it will permanently throw a CEL, though.
Old Jul 14, 2003 | 06:56 PM
96white's Avatar
So the only way I can do this is to buy a 95 96 ECU?
Old Jul 14, 2003 | 07:18 PM
sryth's Avatar
Yes. The 95/96 JWT ECU should work on a 1997 provided the model/transmission match. Now, they have a core charge (pretty pricey IIRC) that you might have to eat, as I don't know if they'll take your ECU in trade. Alternatively, you can just send yours in to have it rewritten.
I don't know about the JET ones, but the JWT seem to be very trusted here. Since JWT makes an ECU mod for your car, I'd probably recommend going with that. I know www.cattman.com sells the ECU's, and even claim that it works on the '97s.
Old Jul 14, 2003 | 07:57 PM
96white's Avatar
When you say "
Since JWT makes an ECU mod for your car, I'd probably recommend going with that. "
My car is the 97 5spd GXE ? They only make it for 95 96.
Are you sayin that they have a 97 ECU?
I am SORRY I am asking so many questions, and keep getting the same answer. I am not very knowageable about the ECU mod.
Old Jul 14, 2003 | 08:07 PM
sryth's Avatar
When you say "
S'ok. JWT makes an ECU mod designed for the '95-'96 which will also work on a '97. The only negative reports I've heard are the CEL stays lit, although nothing's actually wrong. Not all people have this "problem", though.
Do some searching on this, and I'm sure you'll find all the details of using a JWT ECU in the '97s.
Old Jul 14, 2003 | 08:13 PM
96white's Avatar
Ok, I think I got it now. To get the ECU upgrade in my 97 maxima 5 spd. I need to buy a 96 5spd ECU from Cattman and it should work??
thanks for you help so far !!!
Old Jul 14, 2003 | 09:21 PM
sryth's Avatar
Yep, you got it! Although, I don't know what kind of gains I'd expect from an ECU upgrade alone. Usually, people get the upgraded ECU to adjust the engine to NOS/FI or buffed N/A work.
The MEVI owners get it to increase the rev limiter (something that won't help the normal asthmatic Maxima )
bbsitum
Sep 6, 2019 07:31 PM
DCmax
Jul 25, 2001 11:26 PM
1MAX2NV
Jun 19, 2001 03:11 PM
DA-MAX
May 7, 2001 07:35 PM
EZEMaxima
Oct 16, 2000 12:41 PM
