B&M STS Installed
Old Aug 12, 2003 | 11:33 AM
jatt806's Avatar
B&M STS Installed
I got the B&M STS installed on my 01 SE. First impression are:
POSTIVE:
- a lot shorter throw than stock shifter
- shorter stick, feels more sportier
- shifts happen very fast
- looks good with my Momo Combat shift **** and 03 TE shift console
NEGATIVE:
- very notchy, harder to shift than stock shifter
- somewhat off center, when in 2nd or 4th, looks like it's in neutral
Overall I'm happy with it and hopefully it will loosen up with use. Thanks to maxdrvr847(Josh) for installing it for me.
Old Aug 12, 2003 | 01:50 PM
PCGuRu2K's Avatar
Your negatives were exactly how mines were.. It'll get softer overtime.. Also switch to redline synthetic tranny fluid. It'll be a lil smoother from that too.
Old Aug 13, 2003 | 06:41 AM
maxdrvr847's Avatar
Yeah switching to redline fluid would be a good idea, that is what is in mine. let me know
I did send my B&M back, just cause I would prefer having an intake right now over a short shifter.
Old Aug 13, 2003 | 08:06 AM
jatt806's Avatar
Where is a good place to get Redline trans fluid from and how much do you think I need? Thanks.
Old Aug 13, 2003 | 08:22 AM
maxdrvr847's Avatar
its usually about 8bucks a quart, needs 5quarts. I got it from summitracing.com redline ml-90 i think its called
Old Aug 13, 2003 | 08:57 AM
Dave B's Avatar
Not DAVEB the parts guy
Keep in mind that Redline tranny fluid is not compatiable with the bronze syncros.
Dave
Old Aug 13, 2003 | 10:27 AM
jatt806's Avatar
Please educate an newbee, what are bronze syncros? Would a stock 2001 SE 5spd have them?
Also will 5 quarts be enough if I get the transmission flushed out?
Thanks in advance.
Old Aug 13, 2003 | 11:48 AM
96BLUMAX's Avatar
shift_welcome to the club
Glad you like it cause we are losing fans
Old Aug 13, 2003 | 12:36 PM
fhaze_max's Avatar
Dave
Please elaborate muchly.
Like my english?
Old Aug 13, 2003 | 01:35 PM
Mishmosh's Avatar
Man, I'm having a hard time finding regular GL-4 tranny oil locally. It seems everyone carries either GL-5 or stuff that is GL-3,4,5 rated which I'm not sure is safe.
Old Aug 13, 2003 | 04:15 PM
00MAXIST's Avatar
It will get much smoother over time. I didn't even change to Redline and it's now smoother or just as smooth as before.
Old Aug 13, 2003 | 05:19 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Dave
So redline mt-90 is not made for the maxima 5 speed tranny? Please elaborate.
Old Aug 13, 2003 | 07:14 PM
Dave B's Avatar
It's my understanding that there is a coating on the syncronizers that is not compatiable with Redline tranny fluid. The fluid ends up eating the coating which then accelerates syncronizer wear.
Dave
Old Aug 14, 2003 | 02:33 AM
TurDz's Avatar
If this is true, it's a serious problem that should be addressed. I think a lot of people (including myself) run redline mt-90.
Old Aug 14, 2003 | 02:34 AM
Nismo's Avatar
I always heard of gl-5 being harmful but never redline, this is all new to me if its true. where did you hear this from?
Old Aug 14, 2003 | 12:21 PM
nismology's Avatar
It's also to my understanding that Redline MT-90 is fine because it's GL-4. Plz cite your sources because I'm thinking of getting 5 bottles of that stuff.
Old Aug 15, 2003 | 10:58 AM
Mishmosh's Avatar
Redline info
http://www.redlineoil.com/frames/mtlti.htm
Redline MT-90 IS safe for yellow metal synchros.
One alternative may be GM/Pennzoil Synchromesh gear oil which according to their literature is also yellow metal friendly, something GL-5 gear oils are not. To many, this is kind of a "mystery" oil--some have tried it and swear by it, some avoid it because they don't even give a viscosity rating. Normally, some $11/qt at GM dealers, you can also buy a 5-gal bucket at oil-store.com for only $72. You can also get regular Pennzoil 80W90 GL-4 tranny oil in a 5-gal bucket for only $31. (S/H ~$12) 5 GALLONS people!
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
