More Hp Disconnecting Maf?
Old Sep 23, 2003 | 11:01 AM
SLOW96MAX's Avatar
I disconnected my mass air flow sensor after having an injen put on and notice my car seems to pull harder. Is this possible?Any negative effects of it?
Old Sep 23, 2003 | 11:05 AM
nismos14's Avatar
§è~® f®ÈÄk
im surprised ur car even runs with the maf disconnected, mine would just shut off on me till i fully connected the maf
Old Sep 23, 2003 | 11:06 AM
Sprint's Avatar
keep it disconnected if you like it
Old Sep 23, 2003 | 11:11 AM
Stephen Max's Avatar
You might try disconnecting those pesky O2 sensors, too.
Old Sep 23, 2003 | 11:13 AM
MAXimumHP's Avatar
Yes, your ECU has no idea how much air is going in.
Old Sep 23, 2003 | 11:25 AM
The ecu reverts to a limp home mode when there is a maf problem. I think it adjusts afr based on throttle position and maybe O2 sensor information, too, but it also is supposed to limit rpm to 2500 rpm or something like that. The fact that his car feels more powerful now makes me wonder about the state of tune it was in before.
Old Sep 23, 2003 | 12:10 PM
I30tMikeD's Avatar
yYou probably have someting else disconected. Not the MAF because you car would not even be driveable.
Old Sep 23, 2003 | 12:12 PM
[s3]'s Avatar
heh
Might as well remove the TPS.
Old Sep 23, 2003 | 12:31 PM
97GLES's Avatar
my car shuts off.
Old Sep 23, 2003 | 01:04 PM
SLOW96MAX's Avatar
It is the little plug that goes into the side of the intake tube. I think it is the mass air flow sensor. Someone please correct me if I am wrong. I am looking forward to going to the track to see the difference.
Old Sep 23, 2003 | 01:06 PM
Sprint's Avatar
its the intake temp sensor
Old Sep 23, 2003 | 01:08 PM
And it don't do squat for performance.
Old Sep 23, 2003 | 01:11 PM
Kevlo911's Avatar
Kevlo for President
Old Sep 23, 2003 | 01:16 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
if this isn't proof that "butt dynos" aren't worth **** I don't know what is
Old Sep 23, 2003 | 01:23 PM
SR20DEN's Avatar
VQ Wizard
Disconnect your fuel pump and it should be able to attain warp speed.
Old Sep 23, 2003 | 01:29 PM
97GLES's Avatar
if i disconnect my fuel pump i save gas.
Old Sep 23, 2003 | 01:30 PM
nismology's Avatar
+2
ab..
Old Sep 23, 2003 | 01:32 PM
Redmax's Avatar
Redlinemax Owner
sorry bro car wont run with maf disconnected
Old Sep 23, 2003 | 01:48 PM
dpassino's Avatar
hahaha..
Old Sep 23, 2003 | 02:10 PM
meccanoble's Avatar
Sports Button FTW
he meant air temp sensor...might hurt gas mileage...i think car needs to know amount of gas coming in so it can give u proper combustion blah blah blah and what not
Old Sep 23, 2003 | 08:40 PM
Maximamike's Avatar
Who are you?
Old Sep 23, 2003 | 09:05 PM
I30tMikeD's Avatar
Ok, so tell me how the intake temp sense tells the ECU how much fuel is being delivered.
Old Sep 23, 2003 | 09:11 PM
SR20DEN's Avatar
VQ Wizard
Maybe the ECU has a right brain and a left brain. Neither know what the other is doing unless they monitor.
Old Sep 23, 2003 | 10:35 PM
Matt93SE's Avatar
STFU n00b!
in his statement, gas= air, not gasoline.
the IAT measures the temp of the air, so the engine can slightly adjust the fuel mix for best operation.
Old Sep 23, 2003 | 10:40 PM
I30tMikeD's Avatar
I highly doubt he was using the term gas to mean oxygen. But if he was then it would have made sense.
Old Sep 24, 2003 | 05:34 AM
Regardless, the FSM states that the intake air temp sensor is not used to adjust the afr during closed loop operation. It is used as a diagnostic for comparison with other sensors. I forget the precise wording of the FSM.
Old Sep 24, 2003 | 10:19 AM
MAXimumHP's Avatar
I Remember reading that too.
Old Sep 24, 2003 | 11:46 AM
RA030726's Avatar
I'm nutty for Nissans
Ohh man, is this the same guy who checks his muffler bearings for abnormal wear?
J/K
It's OK we all mess things up.
Old Sep 24, 2003 | 03:19 PM
gtr_rider's Avatar
192.168.1.1
@ title
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
maxima297
Sep 30, 2015 03:32 PM
ballerchris510
Sep 10, 2015 09:35 PM
