I have SC whine, but no SC.....Help!
Old Oct 13, 2003 | 10:15 AM
95maxrider's Avatar
Lightly modded
Well, yesterday morning I was driving around, and I stopped at a stoplight. I heard a whining sound coming from my engine, but it was only there when I was idling. If I gave it a little gas, it went away. Last night I heard the noise again, so I don't think it's going away. The car is driving normally apart from that. Any ideas guys? I'm guessing it has something to do with a belt or something.....
Old Oct 13, 2003 | 10:41 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
could be a belt or a vaccum leak...you need to pin point the source
Old Oct 13, 2003 | 10:44 AM
Y2KMaxGXE-R's Avatar
alternator?
Old Oct 13, 2003 | 10:46 AM
ejj's Avatar
ejj
Originally Posted by Y2KMaxGXE-R
alternator?
My alternator made some strange noises before it lit on fire! Be careful!
Old Oct 13, 2003 | 11:29 AM
cardana24's Avatar
Blown
my alternator did the same thing before it went out....mine did not catch on fire, but I had it checked out and the diodes had gone bad.
Old Oct 13, 2003 | 12:26 PM
96shogunmax's Avatar
ac compressor
Old Oct 13, 2003 | 02:03 PM
what's weird about it?
Old Oct 14, 2003 | 05:46 AM
ejj's Avatar
ejj
what?
Old Oct 14, 2003 | 06:00 AM
what?
you had a "weird" sign in your response above
Old Oct 14, 2003 | 06:03 AM
ejj's Avatar
ejj
WERD
There isn't an 'I'.
Old Oct 14, 2003 | 01:48 PM
95maxrider's Avatar
Lightly modded
I had my alternator replaced a few months ago, so I don't think it's that. I like how I didn't get ONE notification about this thread....I had to find it and see. How should I pinpoint the problem?
Old Oct 14, 2003 | 02:44 PM
Craig Mack's Avatar
All YOUR grammer belong to me
"Needs non-maxima friends" needs to be replaced with "clueless n00b"
Old Oct 15, 2003 | 12:58 AM
krmaxima's Avatar
i had the same problem on my 95 i just changed the belts and it was fine i think they got to tight not sure but check your belts. after awhile if u dont change them you will hear that noise at idol and when your driving.
Old Oct 15, 2003 | 06:05 AM
cardana24's Avatar
Blown
you can spray the belts with a lubricant while the car is running....if the whining goes away then its your belts....I used some kind of silicone spray when I checked mine.
Old Oct 15, 2003 | 10:22 AM
Cutler's Avatar
Its your alternator, Run it by Autozone and have them test it or do it with Multimeter. I will bet that is what it is..... Sounds like what happened to me on my old 95......
Old Oct 15, 2003 | 01:26 PM
95maxrider's Avatar
Lightly modded
are you sure? i had it replaced within the last 6 months. i havent been having any troubles with my electrical system either. i dont know if the music has been too loud lately, but i havent heard the noise in 2 days or so.
Old Oct 15, 2003 | 02:07 PM
Cutler's Avatar
Don't matter, they can go anytime....
Old Oct 15, 2003 | 07:27 PM
CullenJ76's Avatar
I had the SAME EXACT PROBLEM. I crawled underneath and figured out that the deflection was off in the belts(one more than the other). I adjusted the idler pulley tensioner and viola, problem solved
Old Oct 15, 2003 | 09:10 PM
tom_98se's Avatar
What about the PS pump being low on fluid? Although it's not under load when you're not turning the wheels...
TOM
James92SE
142
Jan 2, 2024 09:23 AM
CorollaULEV
30
Aug 9, 2021 08:11 PM
homewrecker
Sep 24, 2015 07:01 PM
Andy29
Aug 31, 2015 01:59 PM
ngthing
Jul 6, 2001 04:19 AM
