installing a tranny cooler?
How difficult is it to install a tranny cooler? I have been looking into it recently and would like to know how difficult it is and some of the best brands. Does the cooler come with all necessary components for connection (lines, brackets, etc.) or will i need to purchase extra accessories. Never done this kind of job before so I don't know what to expect. I'm decent under the hood, but I'm just wondering what kind of task i'll be getting myself into. Any input on this would be appreciated. Thanks guys.
The tranny cooler install is pretty simple. You may need some extra hose. About 4 feet of extra hose maybe. I got mine installed in about 30 min.
ZuM
ZuM
Hey ZUM, what brand did you install???
[QUOTE]Originally posted by ZuMBLe
[I]The tranny cooler install is pretty simple. You may need some extra hose. About 4 feet of extra hose maybe. I got mine installed in about 30 min.
ZuM
What brand did you install......just wondering?
ZuM
![](https://maxima.org/forums/images/smilies/support.gif)
You do need more hose ->
Make sure you get the hose that are made for running hot fluild. They have thicker walls. Don't just buy your regular vacuum hose. Make sure you tight down those hose clamps good and check for leaks right away. I didn't at first and they were leaking like a ****. I tried to use those plastic mounting straps, but they turned out to be harder to use. I used the metal brackets instead that came with my kit. I got the Fluidyne ATF cooler that I picked up at AutoZone.
I installed the B&M in my car without a problem. I bought the biggest one that Jeg's had that still had barbed hose connections. I didn't have to buy any hose, they provided plenty.
One of the things I like about the B&M is that the hose connections are on the bottom instead of the side. Also, it's painted black so it blends in better.
MaxLife17
06-27-2019 01:37 PM
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
