Mevi install help
Old Jan 2, 2004 | 10:22 PM
Lost_N_a_97Max's Avatar
Mevi install help
I need help with the wiring of the VI...
I've got the manifold installed, just have to wire it all. I used the vqpower write up but the diagrams aren't much of a help.... anyone who has done the install or know where another write up is, please let me know.... thanks.
Old Jan 3, 2004 | 11:50 AM
anyone with a mevi?
Old Jan 3, 2004 | 02:43 PM
Tatanko's Avatar
Bacon Lover
Originally Posted by Lost_N_a_97Max
anyone with a mevi?
best person to ask is Ian (iansw)
Old Jan 3, 2004 | 02:48 PM
MAXINXS's Avatar
http://forums.maxima.org/showthread....ht=mevi+wiring
Old Jan 3, 2004 | 03:05 PM
Tatanko's Avatar
Bacon Lover
That works, too Way to use your searching priveleges
Old Jan 3, 2004 | 03:12 PM
maxspeed96CT's Avatar
The original VQ...
man mevi wiring looks kinda hard. I hope someone makes a good wright up soon. Good luck man.
Old Jan 7, 2004 | 11:52 AM
Where would i get the vacuum line from? I can't find which hose to use, the pictures i see are from 95's or 96's, I've got a 97.
Old Jan 7, 2004 | 06:06 PM
MAXINXS's Avatar
Get the vacuum from the fuel pressure line.
Old Jan 8, 2004 | 09:59 AM
NmexMAX's Avatar
dot dot dot ...
It's easy.
2 wires to battery (1 for RPM switch and 1 for Vaccuum soleniod)
1 wire to GND from RPM switch
1 wire from coil pack to RPM switch(if using harlan)
1 wire to RPM swithc from soleniod.
Thats it in a nutshell
Old Jan 8, 2004 | 01:42 PM
Where would the relay go in at? Does it help or hinder to have the relay in? Will it keep the intake from opening up? I've read alot about peoples Harlans not working properly, i assumed this was because of bad installs...
Old Jan 8, 2004 | 02:07 PM
JeffesonM's Avatar
living out of a maxima...
I did not use a relay, and my Harlan has worked flawlessly so far. I tapped the RPM signal of a coil pack.
Old Jan 14, 2004 | 12:00 AM
Thanks to everyone who helped.... I've got my VI on and it has worked great so far... Cant wait to get to the track, You were a great help.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
