Got a new toy today (OBD Scan tool)
Today I got my OBD Scan (ordered a week ago) from http://www.ghg.net/dharrison/obdscan.html. I loaded it up on my old Toshiba laptop and started reading the sensor data of my car. Talk about sweet. The device will let me look at things like fuel trim, throttle position, ignition advance, O2 sensors values, MAP, engine rpm, mph, etc in real time. All sensors can be viewed and recorded on a x/y axis too. It will also tell me trouble codes (SAE and manufactuer). The main reason I got it was because my wife's Subaru Legacy GT won't let you pull codes without a code reader or paying Subaru $70 to see what's wrong. It's not a bad deal for $117.
Here are some pics:
In the car:
http://images.cardomain.com/member_i...75_32_full.jpg
The screen with "throttle position" being plotted on the x/y axis:
http://images.cardomain.com/member_i...75_33_full.jpg
I plan to record some values to see which kind of intake the car reacts best too.
Dave
Here are some pics:
In the car:
Dave
That's cool!
Now when you go to the track, you can type on it when you're at the line so you'll be faster than everyone. lol. (Don't forget to slam it shut right before the finish though. )
Wish I had a spare laptop to put something like that in. It'd be a lot more helpful than my Techtom.
Here are some pics:
In the car:
Dave
Here are some pics:
In the car:
Dave
Glad to hear it works well on that ancient laptop you have.
Originally Posted by DanL
Sure beats the $120+ handheld scan tools that just spits out the codes, doesn't it?
Dave
Originally Posted by BSwithTF
That's cool!
Dave
nice dave!
OBD-II scanners rock. One of the best little gadgets I ever bought.
http://forums.maxima.org/showthread....light=Palm+OBD
I highly recommend the Auterra kit.
Pic1: http://mywebpages.comcast.net/stevte...ndPTE_List.jpg
Pic2: http://mywebpages.comcast.net/stevte...dPTE_Graph.jpg
Originally Posted by G20Flyer
Thats cool!
Does anyone know if there is a good/cheap one that works with a Palm??
Remember the data logging aint all that for track or dyno use. It doesnt take samples quick enough. On a 2nd gear run I got like 3samples. Not enough. Not to mention the samples are Comma separated and has words like RPM, and VOLTS in there as well making it harder to chart on a graph quickly. I takes samples like maybe once every 2-4secs.
Dixit
Dixit
I get about 4-6 samples/sec with my Auterra which is plenty useful for track. Exporting to Excel with all of the CSV stuff is fairly straightforward and just requires some fancy Excel footwork.
It's funny, on my Auterra I got extremely slow sampling like you mentioned. But once I disabled "fast-sampling" it suddenly got like a zillion times quicker.
Well for some reason on the Harrison, I can no where near get the samples you are getting. I got like 2samples on a 2nd gear run when I was testing it.
Also the CSV format on the Harrison is bad cause he puts the RPM right after the number like 1000RPM then a comma. So you gotta rip out the RPM if you want to chart it. I know it can be done, but its not a quick thing when you dyno tunning and want to read other parameters while on the dyno to make your adjustments, I dont want to be spending 5-10mins cleanging up the CSV to chart when Im paying $100 per hour to dyno tune. Thats my only rant with the Harrison.
Dixit
Dixit
Dixit
Dixit
Macros will take care of that though.
Nope, just monitor and diagnose. You can pull codes and reset the CEL/SES light too. You need that Nissan CONSULT thingy to actually change stuff like timing and other parameters. I've never seen one for an OBD-1 car, but I'm sure there's some stuff out there on Google to be found.
Dave
Dave
Dixit
Dixit
All you have to do is set up a macro in excel that searches for that text in the file and deletes it.. you could even set it up to do it in Word and just leave the numbers and commas, then save, close, reopen in excel..
I had several years of trimming extra crap out of data like that at an intern job I had... making a macro in excel is EXTREMELY easy, and you can even have it make the graphs and everything with one macro.
then just set the macro to something easy like CTRL+K or something in excel, open the file, click one button, wait 1-2 seconds and the graph pops up.
Originally Posted by BEJAY1
Dave, what does your tool show for long term fuel trim? My stock ECU varied between 4-14%. My TS has no reading after about 125mi. I'm wondering how long it takes to learn and set into the long term ECM memory. And if the TS program disabled this and overides with their own codes.
Dave
Originally Posted by SteVTEC
I get about 4-6 samples per second, but if I'm monitoring 4 different parameters then that's like only 1 round of samples per second if that makes sense. I don't know how many parameters the Harrison lets you monitor simultaneously, but if you're trying to track like 12 at once then yeah, you'd probably get crazy slow sampling. On the Auterra I'm limited to 5 and usually track 4.
Now if you put it in Live Monitor mode where you want it to chart it live, it does that like 4-5samples per second. But obviously no datalogging there, its live graph and keeps going unless you freeze frame it. The palm has ability to do 2 at once, the laptop only one.
Dixit
I take it the only difference b/w the RS-232 tool and the USB tool (besides what they can read) is the interface the make to the computer...Is there any benefit to getting the USB over the serial port tool?...I really don't want to spend $147 for the universal tool, when I will only be using it to read Asian ECUs...
Its reads anything that is OBDII compliant. Its not manufacturer dependant. OBDII is a standard protocal used to access the ECU's trouble code area.
Getting the RS232 over USB or vice versa is just preference and what your laptop can do.
Dixit
Dixit
I hope they update the OBD standards to allow high-speed data connections standard so we can sample every parameter possible 10 times a second
I believe the standard OBD-II data port rate is something like 10Kbps??? (way slower than a modern dialup modem... in fact I think GM extended the standard to allow some kind of 40-50Kbps data rate on some of their ECUs, according to the Auterra manual)
Originally Posted by happyricefob
how does the connection work from the OBDscan device to the ECU? is the installation similar to apexi s-afc/rsm which requires slicing wires and stuff?
Dixit
Dixit
That's not quite correct. While you're right on the mark WRT the RS232 versus USB part, different manufactures do use different protocols. OBD-II (On Board Diagnostics II) supports a number of different communications protocols including PWM, VPW, ISO-9141, and ISO-14230/KWP2000. Nissan and most Asian and European manufactures use 9141 so if you only need to use the code reader on your Max and want to save a few dollars, you can purchase a reader that supports only that particular protocol.
I guess I'll be getting the USB tool...for the price and what it can do, its better than those handheld devices.
Originally Posted by NizanDrivn
So the interface to the computer is irrelavent, speed/samplings-wise or the number "things" that can be simultaneously polled.....RIGHT?
Forge277
06-13-2016 09:26 PM
