Everything about Pulleys!!
I think its my time to get some pulleys, so i have some questions for you guys...
- any problem with your dealer or with your warranty?
- do you feel more power?
- what do you guys know about Motorstorm pulleys? (its very cheap on GD for like $75)
- any problem with your car after that?
thanks...
thanks...
No problems with dealer since I didn't have a warranty when I installed mine, the power gain is not that noticeable, but when you turn your A/C on, the car doesn't slow down any, if you have a stereo I heard it's not a good idea to get a UDP due to the fact it produces less energy, I haven't heard anything about Motorstorm pulleys, and I personally have not had problems with anything since I did my install (knock on wood)...some people say that it starts to leak oil...but maybe because they didn't replace the seal behind it. Hope this helps.
Nick
Postin everywhere huh greek? Just noticed the thing about the AC and Stereo: There is no more lag when you put the AC on, which is awsome
I have two 600 watt subs in my Max, and have had absolutely NO problems with them since installing the UDP last summer. I dont have a capacitor either. Just thought i'd throw that in
Hey there. I got the Motostorm pulley from Tyler in the group buy about a month ago when it was one bill shipped. It is on the car, and I love it. I wont say that it gives alot of power, but it seems to have widened the power band tremendously. I'm running a small sytem of about 300 watts, and I've got no problems. A/C works fine, engine is still very smooth, and I have absolutely no oil leaks from the front seal. I do have a slight squeel on very very cold mornings, and its only because I didn't get the belts quite tight enough. I will be adjusting that today. What happens, is the Aluminum pulley contracts in the cold weather, cause a slight bit more slack in the belt thus causing the squeel. No big deal. Just tightening the belts a bit, and I'm set. Other than that, I love it.
-David-
-David-
-David-
-David-
It feels as if the power comes on sooner, and the car pulls much longer than with the stock pulley. It just feels as though the lighter pulley has "freed" up more power in the parts of the band that were originally the weakest part.
^wow, just like its supposed too.......
Cant wait to get one, I just gotta figure out which brand now
damn.. I was considering getting new pulleys.. However, I am running 3 amps, a yellow top, and a Fared Capacitor.Will i get screwed if a get new UDP'z?
Im running
(2) JBL 1200.1 (1200 watt amp)
(1) JL Audio 300.4 (300 watt amp)
Im running
06-06-2017 02:01 PM
rbarnes
12-31-2015 06:29 PM
