vq30 tranny bolt to vq35 block??
Old Feb 16, 2004 | 10:02 PM
SmokinOdum's Avatar
title says it. I was wondering if its possible/doable to put a 2002 maxima engine in a 1999 I30 auto.
Old Feb 17, 2004 | 03:18 AM
Tatanko's Avatar
Bacon Lover
Got lots of money?
Old Feb 17, 2004 | 05:00 AM
plurco's Avatar
from what I understand this is fairly straight forward, but you have to use all the VQ30's top end. I.E. heads, intake, etc. and jus the VQ35 block. I am sure there is a bit more to it than that, but it has been done with a 5 speed, so there is no reason that an auto would not bolt up.
Old Feb 18, 2004 | 09:13 AM
Thaniel's Avatar
the VQ30 and the VQ35 block have the same bolt pattern. I mated a VQ30 engine to a 350z tranny (350z has a VQ35)
Old Feb 18, 2004 | 09:27 AM
plurco's Avatar
Why????..............
Old Feb 18, 2004 | 09:58 AM
Colonel's Avatar
Old Fuddy Duddy
Read his sig:
"'91 RX-7 being fed a 2000 maxima engine mated to a 350z 6-spd (work in process) "
Its a project car. Obviously a special intention is in mind.
Old Feb 18, 2004 | 11:33 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Not sure how much different the Altima VQ35 5spd is then our 4th or 5th gen 5spd, but you could always got that route since it apparently bolts up.
Old Feb 18, 2004 | 11:36 AM
IceY2K1's Avatar
Speaking of VQ35 with 5spd, if you're serious about doing the *COMPLETE* swap here's everything(engine, accessories, trans, ECU, wiring harness, axles, mounts, etc.) you need from a '02 Altima w/33,527 miles for $3K+freight:
http://forums.maxima.org/showthread.php?t=282049
Old Feb 18, 2004 | 01:04 PM
Kevlo911's Avatar
Kevlo for President
You CAN switch trannies, they are the same for hte FWD ones, but hte drive by wire might be an issue
Old Feb 19, 2004 | 08:27 AM
Thaniel's Avatar
I've been asking myself that a lot lately.
Old Feb 19, 2004 | 08:34 AM
IceY2K1's Avatar
Whoooah!
I like...but you'd better boost that bish. Gearing is going to suck with the VQ-K engine power, especially if thats an autocross car.
Can you keep me posted on your progress?
plurco's Avatar
That picture gives me a "special" sorta feeling.
Old Feb 19, 2004 | 08:37 AM
plurco's Avatar
Originally Posted by IceY2K1
Whoooah!
Run the tranny into a transfer case, jack that ***** up and put some supper swampers on it and don't worry about a driveline tunnel.
Old Feb 19, 2004 | 08:53 AM
Thaniel's Avatar
Whoooah!
The gearing will be a little low. I may have to swap out the rear gear to have a lower RPM for cruising. I really don't drive much on the freeway so I'm not too worried about it.
Boost?....Yah I might. My daily driver rx only has 146 HP and the VQ30de-k has 222HP stock and I won't be running cats and will have very free flowing exhaust. I'll wait and see what it is like first.
here is another pic. I am actually farther than it shows. I just haven't uploaded any new pics. I just need a couple more hours and I can see if the engine will start. quite a bit more time before she drives though.
Old Feb 19, 2004 | 09:11 AM
IceY2K1's Avatar
In that light of a car, it's going to have A LOT more pep.
On my 5spd, it spins high RPM on the hwy stock, but with the 6spd OD, I doubt you'll have an issue on the freeway, especially since that engine has such a short stroke/slow piston speed, it's meant to spin.
Just wondering if the 6spd 1-2-3-4 gearing is going to be real short for the VQ30 torque band, since we don't have near the torque that the 350Z had. Again, the super light weight, may more then make up for it....I don't know.
Any plans to dyno or 1/4-mile it?
Old Feb 19, 2004 | 09:17 AM
IceY2K1's Avatar
Hmmmn...looking at that pic, the throttle-body is close to the firewall.
Any chance in hell you could flip the maniold 180-degrees?
Old Feb 19, 2004 | 09:20 AM
waveridr85's Avatar
when that car is done i will buy it from you, i want that sooo much!
Old Feb 19, 2004 | 09:29 AM
Thaniel's Avatar
Yes the intake is one big pain. I hadn't thought about the fact the intake is plastic before I started. I had planed to cut it and reweld it so it would open to the front of the car. I am still up in the air about it right now. I want to wait until I test run the engine before I start cutting up the intake.
I just have a few wires to connect then do some testing before fipping the switch to see if it will fire. It's been real cold here and so the project has been on hold.
I think it will be a cool car when done. I like how my rx-7 drives but I wanted the Nissan reliability.
Old Feb 19, 2004 | 09:30 AM
Thaniel's Avatar
It's nice to hear you like it. Most people just think I'm nuts.
litch
123
Jan 4, 2024 07:01 PM
howardis
Dec 11, 2019 06:10 PM
fx4five
Oct 18, 2015 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
