TPS sensor/throttle body problem. Need some help
Old Mar 19, 2004 | 04:58 AM
95CustomMaxima's Avatar
Alright heres the deal,
I installed my throttle body today after having it chromed. The throttle body had the Throttle Position Sensor removed in order to be chromed, now I put everything back in and installed it all, but am having some problems. The problem is my Maxima is revving up when I push the clutch in and put the car in any gear..It'll go from idle at ~650 rpm to revving to ~1700-2000 rpm without me giving the car any gas. Then when I put the car in neutral the rpm will fall back to ~650 again. Any Ideas?? Also now when the car is at idle and in neutral and I "blurp" the throttle, the car hesitates and slowly revs up and then kind of bogs down. Please help me guys I really need the help!
Thanks,
-Nick
Old Mar 19, 2004 | 01:19 PM
Anyone have any idea why it revs when put in gear?
Old Mar 19, 2004 | 05:54 PM
CandiMan's Avatar
Say Candyman 5 times
Easiest thing to try is to adjust your TPS. You will need a ohm meter (digital volt ohm/meter) to adjust it properly. There should be 1000K ohms at close throttle and and 9000K at wide open throttle. Of course I'm basing this off my 94 FSM.
MIKE
REDinLV
Aug 15, 2024 12:30 AM
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
