Just installed CAI-sounds sweet!!! long
Old 03-22-2001, 11:35 PM
'Trynna' is not a word
mtrai760's Avatar
Just finished installing my PR CAI. The sound is awsome to say the least. Light rumble with normal acceleration, but it sounds like a max on steriods at WOT, and is silent when cruisin. I couldn't find a 3.25 hole saw, so I used a 3in and ground out a little bit to get the grommet to fit. Advise for anyone attempting this install: Read the How2 posted, it has some good info; The stock MAF bolts will not work with the new plate that comes with the PR CAI, the How 2 recomends 8mm bolts, I ended up using smaller bolts with nuts, because I didn't plan ahead, but it all worked out; install time says 2 hrs, but allow 2-3 if you've never done one before, and take your time, once you cut the wheel well, it's a done deal. The only fitment issue I have is with the fuse box. The intake tubing won't sit low enough to allow me to re-bolt the fuse box to the engine bay. It's kinda sitting loose right now, but I'm going to work on it tomorrow when it's light out. Good luck to everyone.
mtrai760 is offline
matts95max
05-20-2024 01:16 AM
mvm062
11-30-2020 09:00 AM
MaxLife17
06-27-2019 01:37 PM
MaxLife17
09-08-2015 02:36 PM
Maxima30
09-07-2015 06:13 PM
Quick Reply: Just installed CAI-sounds sweet!!! long
