tokico install
Old Mar 24, 2001 | 07:04 PM
sleeper's Avatar
i installed the tokicos. everything is cool except, the drivers side strut is rattling over bumps, i must of did something wrong. sounds like something is loose. but over smooth roads no noise.the notch is facing outward, i guess i'll take it off tomorrow and re do it. any ideas what could be messed up.
Old Mar 24, 2001 | 07:54 PM
NickStam's Avatar
What notch are you referring to?
Old Mar 25, 2001 | 04:12 AM
sleeper's Avatar
notch
the small notch, not the big one. on the top metal cover.
Old Mar 25, 2001 | 06:00 AM
NickStam's Avatar
Re: notch
Did u use a torque wrech when you tightened everything back?
Old Mar 25, 2001 | 07:03 PM
sleeper's Avatar
Re: Re: notch
no. there are only a few bolts that need to be TIGHT. the 2 bottom knucle bolts. you know these have to be real tight. i used a 1/2" breaker bar to untighten these. the 3 on top can only be tighten so far. and the strut rod nut, if there are nylon threads in the nut just tighten all the way down. it won't come loose, right. but i have stillen camber plates and the top nut isn't a nylon one. so i have to drive it down with a impact wrench. or it will rattle loose when driving, found this out the hard way. the rear shock rod nut, should only compress the rubber thing a little, don't press it down alot, just remember how far down the other nut was on the old shock.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
