Anybody know of any gas stations in COLORADO with 93+ octane??
Old Jun 4, 2004 | 09:40 AM
Nick7455's Avatar
I live in Aurora and have found nothing above 91 in the metro area....
Old Jun 4, 2004 | 10:08 AM
NickStam's Avatar
sunocco usually has 93 and 94
Old Jun 4, 2004 | 11:22 AM
Nick7455's Avatar
We dont have sunocco in colorado =(
Old Jun 4, 2004 | 11:41 AM
Sprint's Avatar
pretty sure 91 is the highest in CO
Old Jun 4, 2004 | 12:24 PM
Nick7455's Avatar
That is what i figureed but u can always hope.....
=P
Old Jun 4, 2004 | 12:45 PM
MaximaPolak's Avatar
Higher elevations don't need that high of an octane.....I think that's what it was.....
There is no reason for high octane in Colorado so it isn't too common for the stations to sell them.
Old Jun 4, 2004 | 02:34 PM
Kevlo911's Avatar
Kevlo for President
http://octane.jsalmi.com/
The wonders of Yahoo Search.
Old Jun 4, 2004 | 03:16 PM
Nick7455's Avatar
kevlo911, THANKS!!
I see that there is a station on my way to work =)
It is 93.5 octane but it is like a mom & pop store......what would you say is best: 91 octane from Shell or 93.5 from a small station?
thanks again for all the input!
Old Jun 4, 2004 | 03:18 PM
Nick7455's Avatar
Also the station isnt THAT convienient to get to all the time so if I do get it often but occasionally get 91 from shell is that bad?
Old Jun 4, 2004 | 03:26 PM
98SterlingMax's Avatar
Humble '06 TL Owner
Absolutely correct...higher the elevation the lower the octane requirement...
Old Jun 4, 2004 | 04:55 PM
CanadianMoFo's Avatar
Shell has had bad gas lately. High sulphur content. There was another thread around here somewhere about that issue.
Old Jun 4, 2004 | 05:24 PM
Nick7455's Avatar
We just got shell stations here in colorado about a year ago...they replaced texaco and they cleaned out all their tanks and stuff so I can really tell a difference in their gas but lately I have felt a lil sluggish.....who knows.
Old Jun 6, 2004 | 05:56 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
If I was at high altitiude in Colorado I wouldn't even bother with 93.
High altitude = thinner air = lower cylinder pressures = decreased likelihood of knocking = decreased need for octane level in fuel = it'll probably run at full performance on 89 or whatever they have out there.
If you're not getting knock retard on 89/whatever then going to an even higher octane is not going to help you. Actually, it's more likely that it'll hurt you. So you might be going out of your way for higher octane fuel that you're paying more money for all for your car to possibly perform less with.
It works both ways...
Too little octane = knocking, timing retard, and lost power and efficiency.
Too much octane = poorer combustion effiiciency and poorer combustion rate = ignition timing thrown off and you again lose power and efficiency.
So you need to give engines what they're designed for. At least on my 99, it says right in the manual that in high altitude areas you only need 87 or 89 or so to maintain optimal performance.
Old Jun 8, 2004 | 07:46 AM
02icarus's Avatar
By what theory does higher octane decreases combustion rate? Do you know what octane number means?
Old Jun 8, 2004 | 08:03 AM
02icarus's Avatar
bah, nevermind....i just realized you are talking about lower compression rates, in which case you are completely correct.
chisam14
Nov 6, 2018 08:56 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
