will +45mm offset work on my 99 Maxima
Depends on the width. They would probably fit, but the wheels will tuck under the lips more. YOu would never be able to install any big brake kits because you won't have any clearance.
Originally posted by seven
i know max's use 35-40mm offset but what kind of problems would i run into?
thanks
thanks
I'm looking at some 17x7 rims with 45mm positive offset. Will these work on a 4th gen. I don't know much about rim specs. educate me. Will they tuck in more or stick out more? I don't plan on doing a big brake upgrade. Also what is our bolt pattern? much thanks.
In towards the middle of the car. Less offset makes the rim stick out away from the car.
Originally posted by NickStam
My rims (18x7.5) look about flush with the fender. Any guess on what the offset could be?
You can also look on the inboard side of the rim when it's off... should have a # followed by "ET" ... That will be the offset of the rim...
ah2002
03-09-2016 01:42 PM
criminalslang810
08-16-2015 08:12 AM
kjm900r
08-05-2015 07:14 AM
