Rear Wheel Bearing removal and o2simulator installation questions..ATTN: Jime
Old Aug 17, 2004 | 09:28 PM
95CustomMaxima's Avatar
Does anyone have a writeup or info on taking apart the rear wheel bearings out? And my other question is about the o2 simulator...This question goes mainly towards Jime because I have read a post of you saying you wired one to your rear o2...So how did you wire your o2Simulator into you factory o2sensor? I am asking because I wired up mine and still am getting a CEL. BTW I got a dual output o2 simulator
Thanks,
-Nick
Thanks,
-Nick
Old Aug 18, 2004 | 08:40 AM
DAVE Sz's Avatar
Hooooooonda.....
If it's mainly for JIME why not just PM him?
Old Aug 18, 2004 | 11:09 AM
It's not just for him, its for whoever has a o2simulator. Since I knew he had one I figured to put his name in the title to get his attention.
-Nick
Old Aug 18, 2004 | 11:44 AM
Matt93SE's Avatar
STFU n00b!
rear wheel bearing is not "removable". you have to replace the entire rear hub w/ the bearing inside it.
just remove the brake rotor and the hub cap in the center and the bigass nut behind it. replace the nut when you do the job. they're about $5 from the dealer. clean axle off, add some new axle grease to it, install new hub, torque to spec, hammer the ends down for the locknut safety thing, reassemble brakes.
Old Aug 19, 2004 | 03:54 AM
ryz's Avatar
ryz
removing the hub does not require any special tool s ?
I paid to get mine done if I knew it was that simple
I would have done it myself .Make sure the the hub
center clears your rim ,I am running spacers cause
my wheel would not tighten .The part that the dust cap
goes on is bigger on the new hubs
Old Aug 19, 2004 | 06:09 AM
Matt93SE's Avatar
STFU n00b!
no special tools, just a torque wrench. they have to be torqued to ~190ft-lb.
Old Aug 20, 2004 | 08:59 AM
Stephen Max's Avatar
Hi Matt,
You can't press the bearings out and press new ones in, like the front bearings?
Old Aug 22, 2004 | 01:23 PM
Thaniel's Avatar
Originally Posted by Stephen Max
Hi Matt,
The bearings used in the rear hub are not standard tappered roller bearings that are used in most cars. The hub assy was something like $50. Even if they were replaceable by the time you buy the bearings and have them pressed out and in it wouldnt be any cheaper anyway. The other plus side is that replacing the entire hub is only a few min deal where pressing bearings in and out....
Old Aug 22, 2004 | 09:54 PM
Noone can get the rear hub assembly anymore, everywhere I tried the assembly is discontinued. Any idea what thats about or where I can go to get it?
-Nick
Old Aug 22, 2004 | 10:08 PM
nubiannupe's Avatar
OG Maxima.org Member
-Nick
Have you tried Courtesy? They might have it (or at least source one for you).
Old Aug 23, 2004 | 09:23 AM
Thaniel's Avatar
-Nick
I am sure it is still available. Try a different dealer. Could be the part # that dealer is looking up has been superseeded by another.
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
