funny noise at start up
Old Aug 25, 2004 | 07:03 AM
2kprlmax's Avatar
Hey guys I just went to my car to move it and I went to start the car and it started but then I heard another grinding noise like 3-5 sec after start up. What do you think this could be? Could it be the starter is going bad.
Old Aug 25, 2004 | 11:58 AM
foodmanry's Avatar
Da Roller Coaster!
Yes its the starter. Is this the first time you have heard it? Did you overcrank by chance?
Old Aug 25, 2004 | 12:17 PM
2kprlmax's Avatar
no i did not over crank, but here is the kickerafter I heard the noise i shut the car off and waited and started the car again and I heard the noise. So I go driving around today and stopped to do somethings and when I went to start the car again the noise was not there.
Old Aug 25, 2004 | 01:44 PM
Kevlo911's Avatar
Kevlo for President
Did it go VEHHHHHHHHHHHHHHHHH?
If so, the starter needs to be regreased.
Old Aug 25, 2004 | 04:31 PM
MR_Maxi's Avatar
It could also be a noisy timing chain.
Old Aug 25, 2004 | 10:40 PM
foodmanry's Avatar
Da Roller Coaster!
That is true, and the sound will be intermittant. I regreased mine about 40,000 miles ago b/c I had that problem. Haven't had a problem since....kind of forgot about it.
Old Aug 26, 2004 | 06:34 AM
Grisadiche's Avatar
Mine mad that grinding noise all winter, and once it got warm again it stopped making noise altogether, i can't confirm for sure, but i don't think it is harmful to have it grind, but you'll just have to replace it eventually.
Old Aug 26, 2004 | 06:49 AM
† ErV †
I get it once in like 200 starts.. totally random. Not worth it even bothering with it unless it's constant.
Old Aug 26, 2004 | 08:28 AM
SkoorbMax's Avatar
My 00 does that fairly often when it's cold, but less than half the time. When it's warm it almost never does it. For me it's a metal grinding sound just as the revs peak after starting it. I have heard it's either the timing chain, which in this case is OK and it's nothing to worry about, or the starter, and regreasing it can fix it, or you can just let the thing destroy itself. A year later it looks like I'm taking that route, since I've not touched it
Old Aug 26, 2004 | 09:05 AM
2kprlmax's Avatar
yes it is happening only when it is cold.
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
bennuss
Sep 11, 2015 05:55 AM
trungg86
Sep 4, 2015 04:58 AM
