Strange problems you've had with your car that just seemed to fix themselves?
Old Sep 27, 2004 | 03:06 PM
  #41
Larrio's Avatar
The Definitive AE Master
i've noticed suspension noises seems to just fix themselves for no apparent reason and maybe a different one will pop up later on
Old Sep 27, 2004 | 05:15 PM
  #42
Frank Fontaine's Avatar
My airbag warning lamp keeps coming back. This time I thought it was back for good since the lamp would not go away for over 2 weeks of resetting the computer. So I really moved the power seats around, recline, back, recline, back, front, back, tilt. Now the lamp is gone again. Sometimes it stays away for months.
Old Sep 29, 2004 | 09:19 AM
  #43
maximapitko's Avatar
The Bulgarian Guy
when i got my car the cruise was not working. One day i tried it again and it worked perfect.
Old Oct 1, 2004 | 07:49 PM
  #44
apbrian112's Avatar
my fuel gauge just went dead and didn't read for like 30 secs. (my car had already been idling for a while) and then it just rose up again. it was weird, i've been waiting for it to happen again, but it hasn't.
Old Oct 1, 2004 | 09:19 PM
  #45
Ant96GLE's Avatar
That reminds me of a similiar problem I had. 2 or 3 times my gas needle has gone all the way down past the light! Dont know why, I had plenty of gas in there.
Old Oct 2, 2004 | 10:54 AM
  #46
foodmanry's Avatar
Da Roller Coaster!
My auto start stopped working. I fixed it (loose tach wire) and after that the door locks wouldn't work with the transmitter. Kept coming and going. I finally removed the wire harnesses from the SECU and put them back in. Ever since it has been fine.
Also transmission wouldn't get back in overdrive after I turned it off. This was a few thousand miles after I got the car. So long ago....
Old Oct 4, 2004 | 06:21 AM
  #47
VQdriver's Avatar
my strut bearing would make a popping noise every now and then. it doesn't do it anymore. weird. anyway, recently my speedometer would stop working for a couple of miles from a cold start and my motor would come close to stalling when i came to a stop. this led me to believe it was my gforce ECU that bejay sold me years ago. it happened twice. the first time was coming home from a drifting event at englishtown. i drove my max to meet up with my friend who had my S13. i stopped and reset the ecu and everything was fine. the last time it happened was a couple nights ago starting up the car coming home from pat's cheesesteaks, philly. it was idling weird, close to stalling from a stop and the speedo didn't work. i didn't want to stop b/c it was hella late and i was not stopping in the ghetto. anyway, it fixed itself when i got close to front street. if you don't know philly, it was a couple of miles worth of driving. perhaps the engine got warmer.
Old Oct 5, 2004 | 07:57 AM
  #48
NetFurie's Avatar
power steering fluid
Over the course of a month, I lost almost all my power steering fluid; just vanished. I filled it back up and 4 years later haven't lost a drop.
Old Oct 8, 2004 | 08:45 AM
  #49
Djpic3's Avatar
Door Electrical Problems
My passenger side rear door is totally dead. The window and doorlock.....unless the car gets really hot in the sun all day. Then they both work fine!!! WTF!! Everything else in the car works fine, no matter what the temp. Anyone ever had a problem like this before??
Old Oct 9, 2004 | 12:07 AM
  #50
s0ber's Avatar
A recent one is my CEL light being on since I bought the car, about a month back it turned off on its own and hasn't came back since, for o2 sensor...
I also had the same program as Ant, gas needle would go UNDER E and wouldn't come back on for a while.. Hasn't happend recently anymore.
Old Oct 12, 2004 | 09:11 AM
  #51
{-_-}'s Avatar
my ABS light comes on randomly... and stays on sometimes. but then i would park it a while and then it's gone again. really wierd... brakes are working fine hehe.
Old Oct 12, 2004 | 01:47 PM
  #52
GBAUER's Avatar
My sunroof just stopped working on my '03 SE for about two days. Then, when I was trying to explain to my fiance why I'd have to go and spend a couple of hundred at the dealership, it worked again. When in doubt, try explaining it to the wife i guess. Even the car fears her wrath!
Old Oct 12, 2004 | 05:33 PM
  #53
Ant96GLE's Avatar
Heres a problem I have now thats really getting me angry.. it hasnt happened since winter time and just happened to me again this morning.
When I leave my car over night or during the day stopped for a LONG period of time... say 8 hours or so and the temperature is cold... like last night around 50 degrees or lower... I'll wake up with a dead battery.
It never does it when its warm outside. This morning I went to crank it and I saw the lights dim REALLY REALLY low and the starter barely squeezed enough juice through it to turn the car on.
I've gone through 3 batteries already with the same problem, right now I have a battery thats 1000 CCA's.. its a huge sucker.
I dont know what could be causing this other than something staying on in the car but nothing in the car stays on... Could it be my system? Remote Start?
Oh and the previous owner decided to wire the heated seats to be on ALL the time, I had to remove the fuse or I"ll burn my butt off. I just put it back in since it got chilly this past week.
What the heck is wrong with my car?
Old Apr 25, 2009 | 12:19 PM
  #54
pilot3729's Avatar
When you shut off your car can you hear a slight humming? It almost sounds like your fan is running but it's not. I had the same problem and found out my ABS solenoid was making the ABS motor run while the car was off and it would drain my battery.
I went ahead and pulled the fuse next to the the battery and killed the fuse with wire cutter to the ABS Solenoid till I get it diagnosed and replaced. Something that would drain a battery has to be pulling a lot of amps.
When it's cold it might be the moisture shorting out some unit causing it to remain on.
Old Apr 27, 2009 | 02:11 AM
  #55
ZaxWhite97Max's Avatar
14 to go.
Old Apr 27, 2009 | 07:20 AM
  #56
MoncefA33's Avatar
My SES will occasionally come on for downstream O2 sensors. And then go away.
And then come back on.
It's off now...
Old Apr 27, 2009 | 08:37 AM
  #57
4th_Gen_SE's Avatar
My clock goes off when the motor reaches operating temp, It does it in a weird way though, it fades to black as the temp increases...I have never heard of this before, but if I hit it it POPS back on...fades eventually but at that point i've stopped paying att.
SHIFT_Oh Max...lol
Old Apr 27, 2009 | 08:54 AM
  #58
bigpopaj369's Avatar
the ses light came on 3 years ago when i got the car and it was a speed sensor i had to wait a week for the car dealership to fix it,after 4 days light went out and 3 years later the code never came back
Old Apr 28, 2009 | 06:54 AM
  #59
StnBluPearlMax's Avatar
WOW I sure hope in the FIVE YEARS since he posted this issue that he has fixed the problem.
Way to revive a super-dead thread!
Old Apr 28, 2009 | 07:04 AM
  #60
fat_kid's Avatar
that happened to me, but it came back once, and i think that was after i replaced the speedo head
Old Apr 28, 2009 | 07:17 AM
  #61
ibkevman's Avatar
SES light came on a while back and stayed on for a few hundred miles. the code was for the evap cannister/ fuel cap issue. just magically went away.
I wish that would happen with my left side speaker cut out
Old Apr 30, 2009 | 02:08 PM
  #62
Maxtank's Avatar
I posted here 5 years ago...i've been here to long
I did get the leaking clutch fixed tho!
Old May 1, 2009 | 10:30 AM
  #63
xWasX08's Avatar
That whenever it seems to rain, weather heavy or drizzle, when i start my car, it makes a sort of "Whistling" sound for about 10 mins. I cant really tell where the noise is coming from, nor what it is. So about after 10 minutes of driving the car, or letting it sit (tried both) it will go away. Has this happened to anyone else?
Old May 1, 2009 | 10:04 PM
  #64
82maxtx's Avatar
my windshield wipers quit working one day, I was leaving the car wash and was just trying to do a quick little run of em' to get the water off, and they wouldn't come on, weird huh? they continued to remain non op for about a month, then today, I was out on the freeway, and I saw it was not looking good. well, it started coming down HARD, frustrated, I angrily toggle about my wiper control stick on the column, I power down my drivers window, proceed to reach out in front of the windshield and jerk and pry on the wiper (just being PO'ed) and amazingly, something broke loose and they just started kickin' in!!! I was a HAPPY CAMPER
1st gens, after - midnight postings, run-on sentences FTW
Old May 2, 2009 | 01:05 PM
  #65
PulsarGTS's Avatar
Had an intermittant CEL when running a short ram intake and even which the stock airbox and the GAB. Added a longer section of pipe to the short ram to bring the filter behind the headlight and have never had a CEL since. Better lowend too.
Old May 4, 2009 | 01:08 PM
  #66
NetFurie's Avatar
Two years after I bought the car I heard a strange screeching noise while turning and found that all the power steering fluid had disappeared from the reservoir. Filled it back up and haven't lost a drop in the last 8 years.
Old May 4, 2009 | 03:51 PM
  #67
shadyonedeath's Avatar
-unknown coil pack sometimes mis fires. (99SEL)
-o2 sensor light came on, disappeared and hasnt came back.
-Sunroof makes nasty whining noise if i hold the tilt UP button afters its fully engaged, as if the mechanism and tells it to stop pushing isnt working right. Yet sometimes it doesnt make any noise at all and functions normally.
Originally Posted by njmaxseltd
I wish my problem would fix itself. Can't seem to figure out why I get a miss every so often when it's hot.
It's prolly a coil pack but I wish I'd throw a code to tell me which one.
lol me too man. Mine just started doing this. Got damn 99SELs . CEL wont tell me which one though and i can't do the unplug-test because it doesnt do it often.
Old May 4, 2009 | 04:28 PM
  #68
coyuma's Avatar
my abs light on my dash started flashing in sync w/ my subs for about a minute once about a year ago.....never did it again. that was trippy jaja
Old May 4, 2009 | 09:56 PM
  #69
EEMaxima's Avatar
Was leaking oil. Got an oil change -> leak stopped.
Was leaking gas from charcoal canister area. Leaked once and never again...
Old May 25, 2009 | 11:41 PM
  #70
foodmanry's Avatar
Da Roller Coaster!
Holy old thread bump batman!
Old May 26, 2009 | 09:50 PM
  #71
anovib's Avatar
Damn this threads old enough to read itself.
not really a problem that fixed itself but a starter that won't die.
my starter has been grinding very loudly for 3 years now and is still starting right up every time. (yes i did grease it and it did nothing, and one of the mounting bolt holes stripped completely out in the block so i have one bolt holding it on now)
Old May 28, 2009 | 04:51 PM
  #72
whiteSE's Avatar
car over heated....didnt replace anything, went back to normal
Old May 29, 2009 | 09:22 AM
  #73
HMAX08's Avatar
Thread is old, but hey relevent none the less. This happened to me, 08 maxima pioneer D3 was acting up, had to take it out and get it fixed. Radio are was empty for a few days, my trunk would open wiht the remote and with the button on the trunk lid normally, then one day i went to open the trunk (radio still not hooked up) nada, denied, nothing would open it up, remote, trunk lid button nor the button on the driver door. What was interesting was it lasted a few days then one day, YATZEEE!!! it opened, mind you radio still out. has not happened again, radio back in now
Old May 30, 2009 | 10:45 PM
  #74
Leo_Koneval's Avatar
Haha now that this thread is up why not share!
2 days ago I have a major starting problem, when I try to start the car nothing would happen, there was no noise, no restart of the startup lights, nothing. Then one jumpstart later it started but when I got home, I turned it off and tried to start it again to see if it was fixed but it wouldn't start and had the same silence. I was just about to call a tow truck to tow it to a mechanic to have the electrical system checked out when I decided to try it one more time. And all of a sudden it started and drove like a dream. So far its been a day around town and every where I go it starts up just like it used to.
Old May 30, 2009 | 11:02 PM
  #75
maXspeed96se's Avatar
had a CEL for the cam position sensor but when i changed my egr valve, starter, and fuel filter it went away
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Stagnet04
Aug 16, 2015 11:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
