Uh oh! , 2002 Altima 3.5 se 0-60 6.3 top speed 142!
Re: Re: Yeah but who really cares about top speed?
Originally posted by Russ2kSE
That means the VQ30 has a stronger top end, meaning highway power. So the VQ35 might win in the 1/4 but on a roll its gonna be hard to say.
Thats preaty pathetic that it only does 0-60 in 6.3 and has a top speed of only 142. I meen look at a 95 maxima with only 190{70 less HP then the Altima} , it does 0-60 in 6.6 Sec, which is only .3 slower and the top speed is the same. WTF!? Whats up with that? Am I missing something here?
hmm
i'm highly doubtful that this is the new VQ35 only has a top speed of 142...it's probably on a major restriction from the ecu and such. think about it, it's been a long time since nissan has majorly strengthened the design of the VQ.
anyway, i still love maximas though...i just wish i could see the new 6th gen max...even though i still have a 96. =P
Oh, and check your math. It's only 50, not 70.
The 6.3 is only a preliminary number. . . I am sure this will change to something else, probably lower when real car fan get a chance to push it. It is still a new engine, and I doubt that they are pushing it to the extreme.
Originally posted by Maximus97SE
You are mixing apples and oranges. '95 times are from mags where they do power shifting, and altima times are factory times where they go easier on launches.
MAYBYE THE ECU IS WAITING TO BE CRACKED TO GIVE THE FUUL POTENTIAL OF THE VQ. BTW WHERE DID YOU GET THAT TOP SPEED OF THE ALTIMA I STILL CAN'T FIND IT BRO.
******THOSE NUMBERS ARE A BIT SLOWER THEN ACTUAL BECAUSE IT'S NEW AND IT'S A MARKETING SCEHME(SPELLING?)EX: LOOK WHAT HAPPENED TO THE 99 COBRA FORD PROMISED THOSE NUMBERS BUT IT DIDN'T LIVE UP TO THEM, I THINK NISSAN IS JUST BEING SAFE WITH THOSE NUMBERS. CAN YOU SAY LAWSUIT
Ok I checked my math, I though the 3.5 VQ had 260 HP? I guess they did not tune the VQ for the Altima as much as the up comming max. BTW the top speed is going to be the same if tested by a mag or Nissan. Ohh yeah one other thing, MT does not do power shifting{clearly stated in the mag}, so you better check your info.
youre missin somethin cause 240-190 is 50 lol you got it mixed up with the 260hp maxima lol.... i see what youre saying though that the extra 50 hp should give better figures but then again the 2000 has 32 more hp and 0-60 was 6.7 and the 95 was 6.6 so the 2000 max also should have been quicker with that extra horse..
Its all horsepower to weight ratio. Even though new Altima is bigger, there is a chance that it could also be lighter with chassis and body improvements.
I was also wondering, since it will be a de-tuned version of the 260hp engine, can you retune it to make it 260?
EZ
Originally posted by EZ
I am still puzzeld over that one too!
EZ [/B][/QUOTE]
I know why the 2K max is not faster, it's just silly. About retuning the Alty engine, it is probably just hasdifferent cams,timing etc.
check this out guys, 1st & 2nd gen max's had 160 hp, for the 3rd gen max's they added 30hp to the engines. for the 5th gen max the added another 32hp to that same engine. Now in 2002 what would be the obvious gain in horsepower be.
160 to 190=30
190 to 222=32
222 to ?
160 to 190=30
190 to 222=32
222 to ?
Good question GTR!
Originally posted by gtr_rider
where exactly did you get that information from.
and it does not always pay to be the first kid on the block with the new toy cause sooner or later somebody is gonna one up you.
Uh..i have replicated the A32 0-60mph and 1/4 mile ET's on both 95' and 97' 5-speeds. Both times had NOTHING whatsoever to do with powershifting, no gains are derived from this on the stock block...AMHIK. These were verified with both GTECH and actual track.
As far as this new Altima goes, well it's an awesome car with awesome specs. Let's hope Nissan doesn't screw up the Maxima branding because of this...
-Old Timer
-Old Timer
i know someone who works at a nissan dealership and he said the maxima was supposed to get something like 300 hp but then he said that was the one in the Q45 class so maybe they will just bump right up to the V8 without making the 3.5... i thought that they would use the 3.5 in 2003 then like 2 or so years after make it the V8 if thats what theyre gonna do... they either have to get above the altima in hp or go to a higher class and soon... so no doubt that 2003 will have a lot of changes...
also when they tested the 4th gen they tested it at like 5600 rpm.. the 5th gen they tested it at like 6400 or somethin like that... so right there they cheated on the hp figures a little... if you tested the 4th gen at 6400 wouldnt it be a little higher than 190 then??
Also, one reason the 5th gen isn't that much faster than the 4th, when it seems it should be (aside from weight) is that in the 5th, you must shift at peak hp rather than being able to shift on the down side to keep rpms in the sweet spot.
