mounting EGT probe
Whats the best and easiest place to mount the EGT probe from a EGT gauge? Its a really big concern of mine right now. I would rather now put it in the the header because I would rather not drill the header. I would rather drill the y-pipe rather than the header. But if its best to drill the header. Then I guess I must. Anyone with pics of their probe mounted. How did you guys get it done? I think I'm sold on getting the NOS brand nitrous kit. Going to use the extra money I was gonna spend on the ZEX kit on the gauges. And bottle heater.
ZuM
ZuM
And you don't have any trouble with readings right? Does your A/F meter work well? Do you think I need it? A friend of mine has one on his car and all it does is jump around all the time. I know the EGT is a must have and fuel pressure.
ZuM
ZuM
Originally posted by sx7r
i mounted my egt probe at the very top of my y-pipe, right under the flange. it was easier to get to, lol.
EGT and F/P is only necessary if you are going higher than a 60 shot
ZuM
ZuM
I mounted it to the front header. I left it on when I installed it. I did remove the heat shield. I left the motor running ehrn I drilled it so the pieces of metal would shoot out and not go into the exhaust system. Then when I taped it I used some of that high temp exhaust manifold repair goop on the threads, liquid steel???, it gets harder as it gets hotter. Works like a charm.
who has pic of install. i got my gauges ready but not sure how to install it. Pic of how you guys installed it would be great help. i want to run the wire clean so let me know. i have the EGT and A/F gauge with the dual pod. Also, i heard that you might need extra wires to connect something cux the wire that is included is 3 feet short. think the EGT one was.. please help thanx
Check the link on my sig for some pics at my zing site.
My probe is at the Y-pipe
It's right where the two tubes join togther. Not as accurate as if it was right at the header, but it's better than nothing.
Re: One ?
Originally posted by CandiMan
Is it ok to have the EGT sensor reading off one bank, or is it best to read after both banks
Re: One ?
You could go as far as one probe per exhaust runner. My shop said there are people that actually spent that kind of money. The result...at the most 10 degrees difference between them.
Unclejunebug
Apr 2, 2016 05:42 AM
