HID problem
Old Apr 9, 2005 | 06:10 AM
|Bijan|'s Avatar
UCF Lexus
HID problem
So I installed the Hanabi kit yesterday....I guess you can say I hardwired it into the stock harnesses. The passenger side turned on for about 2 seconds, then turned off.
The driver side works fine. I swapped the ballast, bulb, and starter to the driver side and everything still works. So nothing is bad with the HID kit. Theres gota be something else like a fuse or relay that popped or is no good.
Anyone got any suggestions as to why the passenger side isnt working?
Old Apr 9, 2005 | 06:27 AM
shonufmax's Avatar
help
Get a voltage meter and turn the lights on, check each headlight socket and see if the are putting out the same voltage, and does that side still work with your stock set up?
Old Apr 9, 2005 | 06:35 AM
|Bijan|'s Avatar
UCF Lexus
Well, when the HIDs are hooked up, the voltage meter reads 0 when I touch the 2 wires. So...obviously its a fuse or relay thats shot, but which one?
Old Apr 9, 2005 | 06:34 PM
Zero Deuce SE's Avatar
The fuses should be labeled for the right and left headlights. They should be under the hood in the fuse box.
Old Apr 9, 2005 | 10:58 PM
|Bijan|'s Avatar
UCF Lexus
HAR! It was dark when I looked at it, thought it was good....I found it.
Old Apr 10, 2005 | 06:22 AM
Glad you figured it out. Was it in the engine compartment?
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
