help! my car jerks
Old Jun 4, 2005 | 02:27 PM
1HOTMAX's Avatar
help! my car jerks
when the car is idle, it does not idle smooth, it will be super smooth then a sputter/ the rpm goes down a bit and back up to normal.....smooth for a bit then again. it won't cut off but it's just annoying. is it water in the gas? or is it my fuel injectors?
thanks
Old Jun 4, 2005 | 02:34 PM
THT's Avatar
THT
Throbbing member
You have a 99. How're your coil packs?
Old Jun 4, 2005 | 11:20 PM
TsingTsaoNYC's Avatar
thanks
Maybe you got too much bling?
Old Jun 5, 2005 | 01:33 AM
PARALLEX's Avatar
could be loose fuel lines(the hose clamps have came loose or you may have a cracked fuel line).... just a idea that plagued me for a while till i finally replaced the lines and clamps....
Old Jun 5, 2005 | 07:40 AM
njmaxseltd's Avatar
You have a 99 - Coil Packs!
Old Jun 5, 2005 | 08:14 AM
passEMonTHErite's Avatar
thanks
How many miles?
I had the same issue. Cleaned the throttle body, now its smooth again.
http://www.motorvate.ca/mvp.php/517
Old Jun 7, 2005 | 08:09 PM
1HOTMAX's Avatar
i have about 22k miles now
1HOTMAX's Avatar
how do you check to see if the coil packs are bad? thanks
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kingw323
20
Oct 21, 2015 08:36 AM
Balkins
Aug 12, 2015 06:39 AM
maxima297
Aug 3, 2015 12:50 PM
