Emergency: Please Read
Old May 28, 2001 | 09:20 AM
AlpineMax's Avatar
My car just started leaking what I think is power steering fluid. Its red and is dripping down the passenger side wheel well. I also noticed that the majority of the passenger side of the engine bay is covered in red fluid as well. Do you guys think my power steering pump went, or did a hose just get loose. O and BTW where is the power steering pump located (I have an '89 GXE).
Old May 28, 2001 | 09:41 AM
ZuMBLe's Avatar
Why don't you spend some time and trace the leak? If the pump is gone you will notice it in slow moving situations. But the the fluid cools the pump. So if you lost a lot of fluid while the car was in use. Your pump may have been damaged.
ZuM
Old May 28, 2001 | 10:28 AM
brubenstein's Avatar
One of the high pressure hoses from the pump has developed a crack. Wipe everything down, refill the resevoir, start the car and then see where the fluid is coming from. If everything has ben drenched in fluid, you may need new external drive belts. All hoses deterioate with time and this is not uncommon with cars this old.
Old May 28, 2001 | 11:45 AM
Nick97SE's Avatar
Red fluid?...I think that might be transmission fluid! If so, you could have a serious problem on your hands and you should get it checked out. My 1992 GXE (when I had it) was leaking this, but it turned out to be just a loose hose.
-Nick
Old May 28, 2001 | 03:33 PM
AlpineMax's Avatar
Thanks for all the tips guys, it was just a cracked hose, the pump is still ok.
Old May 28, 2001 | 06:47 PM
Stillnmax's Avatar
red means its tranny fluid .. have fun...
Old May 28, 2001 | 07:20 PM
deezo's Avatar
Remember that if your steering pump goes, you will lose your power steering.
Old May 28, 2001 | 08:55 PM
Eric L.'s Avatar
Power steering fluid is ATF. So, if it were leaking, it would be red.
-Nick
Old May 28, 2001 | 09:12 PM
nismomaxse97's Avatar
You all are right
The red stuff is Dexron Mercon III.
It is used often in trannys and steering pumps.
It can also be used in the gas tank as fuel additive.
More common with Diesel engines anyway.
Old May 29, 2001 | 08:53 PM
AlpineMax's Avatar
i'd just thought i'd give you guys an update. After I replaced the high pressure side hose the steering rack started to leak so I took it down to my mechanic who said it needed a new rack and without replacing that my car wouldn't pass inspection. My mechanic wants to charge me $600 for the new rack including labor is this a good price? BTW: The tranny wasn't leaking, and the tranny fluid was at the right level so I guess it's ok....for now.
Thanks for your help
mclasser
22
Nov 12, 2020 01:58 PM
chisam14
Nov 6, 2018 08:56 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
