2-pc 2004 Maxima rotors are finally here!
Old Jun 10, 2006 | 06:21 PM
  #121
Matt93SE's Avatar
STFU n00b!
they'll fit, but based on your email/PMs, I don't think that's what you need.
Old Jun 11, 2006 | 08:02 AM
  #122
djfrestyl's Avatar
Suspension Yoda
Originally Posted by tripleGmax
can anyone say if the 6th gen brakes would fit a turd gen?
Lol turd gen. So true
Old Jun 11, 2006 | 08:04 AM
  #123
tripleGmax's Avatar
well my car is no turd......
Old Nov 17, 2006 | 01:54 PM
  #124
Nietzsche's Avatar
How long do OEM 6th gen rotors typically last? I drive what you would call "spirited".
Old Nov 17, 2006 | 02:08 PM
  #125
Glude's Avatar
They warp really fast, I had mine turned a few times then finally just replaced with RTP rotors. I would LOVE to have these 2 piece but its just a lil steep for me.
Old Nov 24, 2006 | 10:49 AM
  #126
doublea's Avatar
I'm wondering if these 2 pieces rotors would work out with my SSBC big brake kit ( 12.6" rotor ) ?
Old Nov 25, 2006 | 06:56 AM
  #127
Matt93SE's Avatar
STFU n00b!
Possibly. give me dimensions of the rotors you need and I'll tell you if they fit.
Old Mar 16, 2007 | 06:44 PM
  #128
michaelnyden's Avatar
I didn't know ssbc made a brake kit with 12.6" rotor for our cars...I thought they only offered 12" and 13" versions..
I wouldn't have a problem trying out their brake kit, they are cheap and offer aluminum 2 piston and 4 piston calipers...they just don't offer 2 piece rotors which is why I don't have their setup...I would get the J30/Q45 calipers but they have just as much a poor pad selection as the 6th gen calipers I have now do yet the pads are smaller meaning they can't withstand as much heat as the huge 6th gen pads can....
Old Mar 17, 2007 | 05:59 AM
  #129
chernmax's Avatar
Nations 1st 6th Gen Turbo
LOL, Grave digger...
Old Mar 17, 2007 | 10:38 AM
  #130
yeah I know....revived an old thread...didn't want to start a whole new one though as what I had to say didn't have that much importance to the whole community...
Old Mar 17, 2007 | 05:36 PM
  #131
Matt93SE's Avatar
STFU n00b!
Hey, whatever attention this thread gets is good for me.
Old Mar 18, 2007 | 07:13 AM
  #132
irish44j's Avatar
retired moderator
what are these 2 piece rotors that you speak of?
Old Mar 18, 2007 | 09:21 AM
  #133
GBAUER's Avatar
Before I realized that this was dug up from the grave I did some thinking about the brake rotors here. You say that the weight is about 5 lbs less, but looking at the design, the rotational mass would be about the same and show little to no difference when compaired to the stock Brembos. the outer piece appears to be the same thickness as the stockers. The reason BBK's feel heavy is due to the mass moment of inertia of the rotor. The MMI is more effected by the outer mass than the inner by a long-shot. Therefore, haveing the outer part of the rotor the same would yield very simular results. I just don't see this as an improvement over the stockers, especially for $600! Stock rotors are $125 each new, or about $30 each used (junkyard). You'd be better off buying lighter rims.
Old Mar 18, 2007 | 11:23 AM
  #134
MrGone's Avatar
well for starters you don't have to worry about the hat cracking from thermal expansion and you can prolong the life of your hub/wheel bearings
or you can buy them because they look cool and you'll look like serious business
Old Mar 18, 2007 | 01:24 PM
  #135
Matt93SE's Avatar
STFU n00b!
GBAUER,
Realize there are several factors involved than simply rotational moment.
1. loss of unsprung, rotating weight
Due to the lower total mass, you lower unsprung weight, allowing the chassis and suspension to do their job better. this provides better handling and a smoother ride.
2. thermal capacity & heat management
These rotors have much more surface area, internally and externally. The larger surface area provides more contact surface for the pads, as well as more area to conduct heat away from the disc through the air.
they also have directional, curved vanes providing considerably more airflow and cooling through the rotor than the stock brakes.
this lessens the heat stresses in the metal, causing the rotors to last much longer than the stock discs.
the aluminum hats also transmit less heat into the wheel bearings so they aren't stressed as much and last longer. As well, they prevent rotor warpage by isolating the majority of the heat into a flat disc instead of going up the sides of the hat. this allows the rotor to only expand one direction instead of two.
3. rotating mass
I haven't done the math (namely because I haven't spent the time to measure and calculate everything since they work so much better). but even though the rotors are larger than the stock 4 and 5 gen (same dimensions as stock 6 gen), I would venture to say they still have very similar or even lower total inertia moment due to the lower total mass.
4. Material.
These rotors are made of a much higher quality iron than the stock-type cast iron rotors. I've read before these are forged steel due to the hardness, but I'm still under the impression they are pure iron since that's the best material for heat conduction and withstanding thermal stresses.
What's the mean in english?
My custom 13" 2-pc rotors (made by the same company at the 12.6") are almost 5 years old and have thousands of track laps and 40,000 street miles on one set. Generally I would expect to replace stock rotors every 40k miles, and once or twice a year under heavy track use like what these have seen.. so all-in-all, I SAVE money and increase performance by using these rotors.
Old Mar 18, 2007 | 04:25 PM
  #136
irish44j's Avatar
retired moderator
George...matt's response covers it all.
but let me tell you from firsthand experience, having switched from the OEM 6th gen rotors to the 2 pc, switched back for winter, and now put the 2pc rotors back on again: THE DIFFERENCE IS SIGNIFICANT.
It is MORE of a difference than swithcing from my 25lb 18s to my 17lb track 17s, for acceleration. Also the reduced unsprung weight really improves ride quality over rough roads, and makes the steering feel much quicker and lighter....
Bottom line: the 2pc rotors was probably the single most expensive mod I've done to my car (except wheels), and I consider them to be worth every cent - especially when paired with the z32 calipers.
Old Mar 18, 2007 | 08:11 PM
  #137
MrGone's Avatar
You need a Fidanza
Old Mar 18, 2007 | 08:16 PM
  #138
MorpheusZero's Avatar
Originally Posted by MrGone
You need a Fidanza
+1
mushroom, mushroom
Old Mar 18, 2007 | 08:25 PM
  #139
irish44j's Avatar
retired moderator
You need a Fidanza
there are alot of things I need......
but selling my POS townhouse and buying a SFH with a 2-car garage is higher on my priority list at the moment
Old Mar 18, 2007 | 08:27 PM
  #140
irish44j's Avatar
retired moderator
chris with all the bling on your car, I'm a bit surprised you haven't picked these rotors up yet. especially with those new wheels you're getting...everyone is going to be able to see the ugly OEMs
Old Jan 3, 2011 | 04:37 PM
  #141
joesae01max's Avatar
bumping an old thread..are these still being made Matt?
Old Jan 3, 2011 | 05:39 PM
  #142
Matt93SE's Avatar
STFU n00b!
They're not "being made" anymore, but I still have some of the original batch in stock.
$550 shipped to NY if you're interested.
Old Jan 4, 2011 | 01:20 PM
  #143
do they happen to be the slotted ones or the blanks?
Old Jan 4, 2011 | 01:36 PM
  #144
Matt93SE's Avatar
STFU n00b!
Everything I have left are the blanks.
03VQMAX
Sep 25, 2015 04:19 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Costa068
Aug 17, 2015 02:13 PM
soon2ownmax
Aug 13, 2015 02:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
