What do they do to align your car?
I was wondering what is actually adjusted during an alignment.
When I bought the car, I asked if it had been aligned when he put the suspension back on and he told me that he (and a friend I imagine) used rulers (his words) to align the car. The alignment was near if not perfect when I drove the car from Nashville back to Atlanta and up untill the point when I had to replace my axles.
I am interested in learning how to do this because of the D2s and the ride-height adjustability among other things.
Any of you guys align your cars yourselves?
I could be wrong but you shouldnt have to be aligning your car everytime you change your ride height.
The fact that two guys did a near perfect alignment with some rulers sounds pretty unbelievable.
You have to do alignment with the computerized machine like Tim mentioned above. The process is a bit complicated. You have to adjust your toe and camber. Tie rod ends and strut bolts (oval one) are where you do the adjustments but you need the alignment computer to do it correctly. It's better leave to the mechanic to do it. Price range between $80 ~ $150
As for that firestone lifetime alignment thing. It may be different other places, but here firestone doesnt sell lifetime alignments to lowered cars.
Originally Posted by nadeemp8
You can go to a local firestone and pick up a lifetime alignment on special for $99 and go back as much as you'd like and they'll align it with their Hunter machines....
Originally Posted by looslip
When I went to hook this up, they said that they couldn't take any wheels larger than 17". I was kinda bummed about that but maybe its different at other Firestones.
wrong and wrong.
your alignment changes with ride height. so any time you adjust anything on the coilovers, you must realign the car. minimum toe should be checked, but camber you can usually let go as long as it's not too crazy.
and yes, you can check the toe with a couple of tape measures. racers have been doing it for years.. do some research before you randomly guess at crap like that.
i know i should probably just call and ask, but if i got a lifetime alignment somewhere, would that be valid nationwide at all of that companies locations? also, what is a good price? i think the best i had found was around $60-80. not sure. but maybe lifetime would be best if i plan to work with the suspension some more.
I think I will end up taking it in.
The rulers thing was not like something I made up, that's why I quoted it.
This was a guy who swapped Turbo SR's in Sentra's every other weekend so I do not doubt that he knew what to do. How long it took? I do not know, but I drove the car home from Nashville (around 300miles) and let go of the wheel multiple times.
The MAIN reason I NEED it done is because I just did both axles, it would just be HANDY due to the adjustablility of my suspension.
Lakersallday24
06-16-2019 01:35 AM
