Jacking safety question, urgent (in the middle of my suspension...)
Old Mar 2, 2006 | 08:47 AM
BigLou93SE's Avatar
I was hoping to swap the front tires for the back and vice versa (directional tires), and the easiest way that I can think about doing this is jacking the whole car up with four stands.
I did this when I did my brakes, and worked fine, but for some reason today it looks unsafe to do, as if the car would tip if I now tried to jack the front end up and place stands under with the rear ALREADY on stands. I'm using the factory stand points, and the rear stands look very "forward" (in relation to the front of the car) sitting in this position.
Is it safe to jack the front up at this point, with the rear already in the air, and the tires off, and place stands under both the front and rear of the car at the same time?
For now I'll leave the front on the ground and do my rear suspension for now, but the quicker response the better. Thanks.
(For clarification: the rear factory stand points look as if the "pivot" point of the car (when jacking up the front end) will be too far forward, and the car would have a tendency to fall back on it's back bumper. Obviously, I would rather swallow my pride and ask now before you see a thread entitled "my car fell to the ground while jacking it up". You get the picture)
Old Mar 2, 2006 | 10:00 AM
Mizeree_X's Avatar
Getting back to his roots
I've done this on my 3rd gen multiple times with no problems, but my jacking points may be different than those for a 4th gen.
Old Mar 2, 2006 | 10:17 AM
Progress's Avatar
It's business time.
Do you have the wheels on? If you are going to use four stands and are worried about it, leave all the wheels on at first. Once you have the car jacked up with stands then rotate the tires.
Old Mar 2, 2006 | 12:51 PM
ramberg's Avatar
GrandPa
Why don't you just go to Sears, they will do it for free. They did mine in Florida when I was there.
DJLAX152
May 4, 2021 11:46 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
James92SE
Oct 8, 2015 04:57 PM
homewrecker
Sep 23, 2015 03:41 AM
