Poly-Urethane Engine Mounts
For those of you that have filled your stock mounts with poly-urethane. What product did you use?
How long have the mounts been installed for?
Are the mounts weakening due to heat from the exhaust manifold like what was happening with the place racing engine mounts?
Any products tested that I should stay away from?
Anyone use epoxy as opposed to poly-urethane?
Your helpful input is much appreciated.
Originally Posted by Lordrandall
Urethane from McMaster Carr
Been in 2.5 years
Nope, no weakening that I can see. Still going strong.
Been in 2.5 years
do you remember what durometer the urethane was?
http://www.cardomain.com/ride/352601/8
i might have some helpful pics there for you. i used Shore A 80 urethane (part # 8644K11) purchased from www.mcmaster.com
have had my mounts filled for almost a year and no problems yet.
Originally Posted by SPiG
I did my real trailing arm bushings. Again so far it has worked great. Just nasty stuff to work with. Gloves are a good idea.
derekinthez
Nov 13, 2022 04:00 PM
ballerchris510
Sep 11, 2015 05:29 PM
