Burned out headlight wiring
Old Jun 28, 2001 | 10:38 PM
bigbadboss101's Avatar
I have a 99 SE and I put in a pair of 9004 Plasma Blue lights a few months ago. Recently I noticed one of the plugs was partially melted. Therefore, low beam didn't work, and driving light and high beam did.
I took it into the shop today and they said the aftermarket lights was 100/80w, which was too high.
Should this wattage be ok?
Old Jun 29, 2001 | 12:53 AM
maximapowr's Avatar
This is true
The higher wattage bulb will produce more heat. The same thing happened to my harness as well. A simple fix is to buy another harness at your local auto parts store. They have universal harnesses for all headlight bulbs. The only cost 4 or 5 bucks. All you have to do is cut the old one off and wire up the new one. Or you can go back to your factory bulbs or find a lower wattage aftermarket bulb.
David C.
Old Jun 29, 2001 | 05:22 AM
1MAX2NV's Avatar
Get APC wiring Harness if you plan on running 80w/100w. If not, go to pep boys and get the 9004 socket. Make sure you use good ground points when you decide to use the APC wiring harness.
Old Jun 29, 2001 | 05:24 AM
1MAX2NV's Avatar
Re: This is true
David,
That's a nice paint job and system. Good work.
David C.
Old Jun 29, 2001 | 05:48 AM
AntGVR4's Avatar
i had the same problem except my entire harness melted so bad it became a Lump of plastic ... this is not good
this is wut i did
and i DON'T recommend doin it unless you've done this stuff b4
cut off the old harness, go and buy Crimp connectors and crimp one onto each wire and slide them onto the headlight and you're done .. of course if they connectors should move while the light is on you will fry your entire lighting system .. of course now if you put 200W bulbs in the connectors won't melt
Ant
Old Jun 29, 2001 | 07:25 AM
matt92gxe's Avatar
tell me where i can get an apc rewire before my nokya artic whites melt!!!
mclasser
22
Nov 12, 2020 01:58 PM
doctorpullit
Oct 28, 2019 10:58 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
