Alternate Headlight cleaning method "No more wet sanding???"
Old Dec 28, 2006 | 05:44 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I just pulled this link off the NYCMaximas web site, check it out, may help some of you clean older or yellowing headlight lenses with Brasso...
http://www.g20.net/forum/showthread.php?t=57038
Oh and if this has been posted already, suck it up...
Example of Before / After using Brasso
Before
After
Special thanks to NYCMaximas members FuLLaH from the info/find and jitiola for the before and after pictures...
Old Dec 28, 2006 | 07:54 AM
Kevlo911's Avatar
Kevlo for President
Yeah, I read about using aluminum polish the other day. I will try it out today and see how it works. I will be using the Mothers polish I have tho.
Old Dec 29, 2006 | 09:27 PM
cefiro80's Avatar
Still seems a little hazy. Aluminum polishers work to a point but dont work on heavy pollution as good as wet sanding. It is a good maintance step afterwards to keep them clean. Also, you can check out the product flitz. Also, remember to add you headlights to your normal car cleaning and maintance. Make sure they are cleaned and waxed to protect them.
Old Jan 1, 2007 | 03:12 PM
Maximus_95's Avatar
there are a few products now days you can get from a kragen's or autozone that can do the same.... i bought one, forgot the name but it worked very good~
Old Jan 1, 2007 | 03:29 PM
djfrestyl's Avatar
Suspension Yoda
Looks like the same amount of improvement any ordinary plastic polish would do. There's still some significant pitting in your headlights from what I can see, and wetsanding would probably be the best way to get them *completely* clean and remove the pitting.
Looks great for what it did though!
Old Jan 1, 2007 | 04:09 PM
Kevlo911's Avatar
Kevlo for President
I used Mothers Aluminum Polish and then I used Meguiers 3step paint system and mine turned out great, they look new.
Old Jan 1, 2007 | 07:47 PM
DrKlop's Avatar
Driving is the next best thing
Tried this as well. Makes a noticeable difference even after one application.
Old Jan 2, 2007 | 04:01 AM
nismology's Avatar
Come do mine...
Old Jan 4, 2007 | 03:05 PM
RA030726's Avatar
I'm nutty for Nissans
Rubbing compound works better
Old Jan 4, 2007 | 03:20 PM
Jeff92se's Avatar
I'm needing a caw
Nothing magical about your discovery. It's just a diff grade of polishing compound. Even sandpaper can be seen as polish. Just very, very rough. Metal, plastic,car polishes are all similar. Just different amounts of abrasives.
If your plastic is real bad, I'd try rubbing compound as mentioned above. It's probably like a 1500 grit sandpaper give or take. But you definately would have to follow that up with one or two more steps of finer polish. ie.. rubbing, Mequires # 3 then plastic polish. etc..
Old Jan 4, 2007 | 03:23 PM
Greeny's Avatar
¯\(°_o)/¯
I used r/c on my mom-in-law's sentra lights,turned out great..
Old Jan 4, 2007 | 03:38 PM
Maximaaa's Avatar
Wow, I used that stuff and it really does work! Nice find!
Old Jan 5, 2007 | 12:34 PM
kcryan's Avatar
Sure you did....or wait maybe you didnt and your just trying to build up posts?
Old Jan 5, 2007 | 03:57 PM
Kevlo911's Avatar
Kevlo for President
Did nothing for me. Might be because I have Turtle Wax brand tho. But the Aluminum polish worked 10x better than the rubbing compound.
Old Jan 5, 2007 | 06:15 PM
Apparition's Avatar
Ichiban King
Completely true. "Never Dull" also works..
Old Jan 6, 2007 | 11:22 AM
whazzzzuup's Avatar
It depends what condition your headlights are in. If the headlights have pitting and other heavy scratches, a heavier/rougher abrasive will be needed to return the headlights back to new condition. The owners should be able to determine what product will work for them.
Old Jan 6, 2007 | 04:38 PM
kdaullary's Avatar
Go to Autozone or Advance auto go to the car cleaning isle and by the headlight refurbisher kit. its like ten bucks. they look like sanding discs that u install in a drill chuck this works very well used um a mustang witch is well nown for headlight fog up
DJLAX152
May 4, 2021 11:46 AM
AaronL
Nov 15, 2020 11:52 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
sdotcarter
Sep 2, 2015 09:53 PM
