Sidemarker installation
Old Jul 12, 2001 | 07:19 AM
Supa Lao's Avatar
I think I saw somewhere that someone has a write up on how to install sidemarkers. Can someone give me a link? Cumalot, can you tell me how you did your wiring. I'm thinking I want to wire mine the same way you did.
Old Jul 12, 2001 | 07:24 AM
Sprint's Avatar
Uncle Bens
Old Jul 12, 2001 | 07:40 AM
Supa Lao's Avatar
umm....I'm not sure if it's because I woke up or not, but what do you mean Sprint?
Old Jul 12, 2001 | 08:30 AM
Sprint's Avatar
What product does Uncle Ben's make?
Old Jul 12, 2001 | 08:41 AM
redmaxpa007's Avatar
i SeE what you did therE
Since the moderator is watching.....
[innocent post] dex... ready..... sprint is saying what your doing is RICE [innocent post]
Old Jul 12, 2001 | 11:42 AM
Cumalot's Avatar
This information was given to me by a fellow member, Slickismax. Hope this helps.
Subj: Re: Cuzo sidemarker
Date: 12/29/00 10:54:47 PM Central Standard Time
To: MChiang21@aol.com
What I did was make a little cardboard "template" showing me where the sidemarkers will be, so that way they will be even on both sides. Then I taped the sidemarkers on backwards, so that they are face down on the fender. Then I made a mark on the fender where the hole needs to be using a bit that fits inside the sidemarer hole, I beieve I used a 1/2" bit. Then I removed the sidemarker, and drilled the hole using the 3/4" drill bit. Then I put the sidemarker in, and drilled the two holes for the mounting screws. I bought my bit at Ace Hardware, it was about $15. As far as wiring, I connected the brown wire the the positive wire from the corner light, and connected the gray wire to the positive wire from the turn signal. I had to run wires to both. Don't connect them to the battery, or else they will be on all the time. If you wire them the way I said, they will come on with your parking/headlights, and they will flash with the turn signals too. If you need any more help, let me know.
Bill
Slickismax
Old Jul 13, 2001 | 05:25 AM
Albertt's Avatar
Supa Lao: I only suggest one change >>
Do not wire them to the parking lights. Turn signal repeaters are only supposed to light when your turn signals/hazards are flashing. Wire them to the hot lead of the front bumper turn signals (the pair at the front of the bumper). Make sure you put a little sealant to prevent moisture from entering the hole you just cut in the fender. In fact, it might not be a bad idea to put a little touch up paint on the exposed metal area that you just cut into.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
