anyone with a HKS SS BOV?
Old Oct 24, 2001 | 07:28 PM
Cumalot's Avatar
I'm thinking of swapping out the Blitz for the HKS one. My Blitz is a bit messed up, don't ask.
I know Mardigrasmax has one, but when he bought the SC, it was on there already. I know you have to weld the HKS onto the piping, but how? I bought the aluminum flange that was needed for the welding. Will there be any cutting involve? I look at the flange that I bought and it just look a bit weird. I don't see how it could be weld onto the piping unless there's a bit of cutting involve. And where could I go for the welding? Body shop? Thanks.
Old Oct 24, 2001 | 07:38 PM
thebigsadler's Avatar
Re: anyone with a HKS SS BOV?
you think i can mount it into my intake?? lol.. sorry
Old Oct 24, 2001 | 08:24 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
yrea i got HKS BOV...but mines a turbo...hahaha. uh, if your piping is aluminum then get the aluminum flange, if its steel, you get the steel one. Yes, it needs to be welded on. aluminum is harder to work with then steel, so make sure whoever is doing it is good. Fabrication shops, some exhaust shops and some performance shops should be able to do this. Id estimate under 1 hour labor.
Old Oct 24, 2001 | 09:05 PM
My 4DSC
if you have to weld...
MAKE SURE there are no leaks...
the only way to be sure is to fill the pipe with water and blow pressurized air on the outside of the pipe near the welds...
if you see bubble rise up thru the water you got a leak...
took us ALOT of time and welding to get it not to leak...
ANNOYING.
Old Oct 24, 2001 | 09:42 PM
got rice?'s Avatar
HKS' SSBOV is overkill and over-priced for the amount of boost you guys are pushing. Go with the A'PEXi or GReddy units..
Old Oct 24, 2001 | 10:21 PM
Chunger's Avatar
My other car is a Hybrid
With the price of the flange and welding added... I think you might as well get the Blitz which just bolts onto the Stillen SC kit...
Old Oct 24, 2001 | 10:51 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Re: if you have to weld...
ANNOYING.
Thanks!
Old Oct 25, 2001 | 08:03 AM
Cumalot's Avatar
The SC piping on my car is aluminum right? Hm...seem like a lot of trouble, maybe I should just return it.
Old Oct 25, 2001 | 08:50 AM
Loren00Miata's Avatar
The supersequential BOV does not make an SC car faster, instead it cause compressor surge and will damage the seals and bearings in the SC. I strongly suggest you talk to Steven at Vortech about. If you have done it, don't mention it to him or they will immediately void the warranty. The SSBOV is designed to control the speed of a turbo compressor wheel to help spool up by varying the amount of pressure that is vented. The problem with it on an SC is that the compressor wheel speed is set by the engine. When the SSBOV opens, the throttle plate closes and it doesn't vent the pressure, either the air will have to back through the SC(this is what damages the seals and bearings) or if the tension on the belt isn't high enough then the force against the compressor wheel will jam up the SC and cause the belt to slip over it. Neither are desireable, so don't do it.
Old Oct 25, 2001 | 09:44 AM
Chebosto's Avatar
RIceD OuT moDErAtor
the blitz is a good BOV, but out car just makes too little pressure to actually make a "loud" enough burst. more of a low "Douuuuuuuu" than a high-pitched "FFFSSt" that is common in supras or rx7.
the Greddy Type S has a high pitched bov, but the racing type R bov is more like a "DEwwww"
there is TurboX's bov for boost under 12psi. which gives a generic fizzle, which is similar to Apexi's design and sound.
the HKS is sequential and not really that great for superchargers, but it does have a loud bov for low boost and highboost applications that are on cars like supras n stuff.
Old Oct 25, 2001 | 10:11 AM
Cumalot's Avatar
Oops, I forgot to say that I didn't purchase the HKS BOV yet. Typo of my part. I was just thinking about it, that's all. The Blitz is a good BOV, it just that the adjustment screw is kind of stripped because of my fault.
Cheston, how's your car doing? Everything is smooth now?
Loren, what size pulley are you running?
Btw, I might go Kev's route with the smaller pulley size.
Old Oct 25, 2001 | 12:15 PM
got rice?'s Avatar
I wouldn't put any TurboXS products on my cars..
Old Oct 25, 2001 | 12:31 PM
Y2KevSE's Avatar
Break the 3" barrier!!!
Old Oct 25, 2001 | 12:43 PM
Cumalot's Avatar
You think the automagic could survive the smallest pulley available?
The auto tranny is getting on my nerves. Even with the VB, it is still not good enough. Too bad a 5spd swap is just too costly.
Old Oct 25, 2001 | 02:15 PM
Turbo95Max's Avatar
hey mr CumsAlot,
ill take that flange if you want to sell it
look at Cheston, being a knowit all. wow BOV EXPERT!!! hahahah
the sound also varies how much boost you run and design of piping. Ever noticed that ANY bov on an MR2 is loud? most of my honda friend's that have Apexi sounds like a lazer, dunno anything bout a fizzle...haha
Old Oct 26, 2001 | 04:11 AM
Lyt97SC
lol
Old Oct 26, 2001 | 12:10 PM
skimax's Avatar
uhm... YEA...
bottom line, no bov sound good on our stupid sc'd cars...
Old Oct 26, 2001 | 12:33 PM
Y2KevSE's Avatar
Originally posted by skimax
uhm... YEA...
Thanks for pointing that out... now go back to your corner.
Old Oct 26, 2001 | 01:34 PM
skimax's Avatar
PUNK B*TCH, i should drive up there and smoke your a**!!!!
Old Oct 26, 2001 | 02:07 PM
Y2KevSE's Avatar
Old Oct 27, 2001 | 02:19 PM
Chebosto's Avatar
RIceD OuT moDErAtor
if you count backfire at start... if it DOES start. then yes. everything is fine.
*sigh*
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
Dave B
Jan 11, 2001 05:59 AM
Dave B
Jan 8, 2001 09:57 PM
Avalon Racing
Dec 10, 2000 09:45 AM
