Nissan/Infiniti have faulty sunroofs?
Old Jul 7, 2008 | 11:35 AM
speed3000gt's Avatar
Has anyone on here had their Sunroom leak during a heavy rain? I've come across a few Nissan products ( mainly late '90s Infiniti) that have leaky sunroofs.. Is there an easy fix/solution to this common problem..... or is it not too common?
Old Jul 7, 2008 | 11:54 AM
Pearl93VE's Avatar
I can has?
Mine leaked when I got it, the stupid previous owners neglected the sunroof drainage hoses so where the exited behind the rear tires, the Y fitting that connected the power antenna's drain hose and the sunroof's drain hose (on the passenger hand side) was completely rusted shut and had debris blocking it. I took it off completely and let the hoses run right out onto the ground after zip tying them to stay in place and I haven't had a problem since.
Old Jul 7, 2008 | 12:01 PM
From what I've read many, many times here on the org over the years, the clogged drainage hose as describe above is the leading culprit of sunroof leaking problems. Check it out and report back to us.
Old Jul 7, 2008 | 12:30 PM
Whats involved with getting the old hoses out? Its actually not my car but my aunt's Infiniti QX4... But nice to know some preventative maintenance on my car
Old Jul 7, 2008 | 01:12 PM
NismoMax80's Avatar
SuPeRmOd
isn't it common knowledge that after time all sunroofs will likely leak?
seems like the drainage maintenance is key with Nissan.
Old Jul 7, 2008 | 01:18 PM
You don't take the hoses out (at least the sunroof one anyway, the radio antenae you can if you want), just get access to them and unclog them per the directions above.... You'll see once you get in there.
Old Jul 7, 2008 | 04:52 PM
redls1's Avatar
MAXIN' ON
Mine hasnt leaked but got jammed up. They replaced the track to a tune of $1500 (under warranty).
Old Jul 7, 2008 | 05:49 PM
Pearl93VE's Avatar
I can has?
Yes, don't undo them... you can test if yours have clogged by spraying compressed air down into the tubes from the sunroof... or find where the hoses exit underneath of the car behind the rear tires.
However, I wouldn't disconnect/disregard the power antenna tube, you don't want it draining water into your rear quarter panel. I'm not sure about other gens, but in my third I can access the tubes from my jack area...
Old Jul 7, 2008 | 06:28 PM
internetautomar's Avatar
mod or sell?
when my 3rd gen leaked it was because the rails were broken. Fixed the rails, stopped the leak.
this POS 4th gen has a whole TSB on how to fix it, plus a $100 kit that is part of the fix for it : for now I just hope for no heavy rain.
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
