Help with UDP install
Old Nov 8, 2001 | 09:44 AM
thw625's Avatar
How do you release the tension on the belt that drives the power steering pump? I loosened the small bolt behind the pulley and then got at the other bolt that runs vertically from underneath but the pump does not move. What am I missing? Thanks
Old Nov 8, 2001 | 10:24 AM
emax02's Avatar
Re: Help with UDP install
http://integra.vtec.net/geeser/megamax/60k_service.html
Old Nov 8, 2001 | 11:22 AM
thw625's Avatar
Re: Re: Help with UDP install
I did exactly what it says to do in that link but it doesn't work. There's got to be something else going on there.
Old Nov 8, 2001 | 12:21 PM
Jeff K's Avatar
Re: Re: Re: Help with UDP install
Once you loosen the horizontal nut locking on to the vertical thread bolt then start to turn the bolt maybe the oposite of what you think. I remember turning and turning but nothing was happening. You need to actually tighten the vertical pump threaded bolt so that it will make the "C" shaped clamp smaller...that will lower the steering pump.
Old Nov 8, 2001 | 01:09 PM
sinewave's Avatar
There is also a bolt that the pump pivots on that has to be loosened. IIRC, it is on the back side of the pump. I do remember that it is a PITA to get to. You have to crawl under the car and get to it from below.
Old Nov 8, 2001 | 03:50 PM
yourmove's Avatar
Re: Re: Re: Re: Help with UDP install
Yup, I agree! I had the same problem. I would seem you should turn the tensioner hardware one way, when it actually goes the other way! I beleive you turn it to the right. Watch out for the threaded bolt walking out of the cheap set up!
Old Nov 9, 2001 | 05:40 AM
Lime's Avatar
uhm, I haven't looked at the 5spd's, but the way I did it was to get a big 3/4" impact gun (more power) with a deep socket and just grab the thing right off with the impact gun.
Old Nov 9, 2001 | 06:11 AM
thw625's Avatar
So are you saying that you have to force the vertical bolt up into the metal bracket that holds it until the whole bracket moves? Also, what's the deal with the bolt on the back of the pump? You guys that didn't mention it, were you able to move the pump without loosening that bolt?
Old Nov 9, 2001 | 06:45 AM
sinewave's Avatar
Here is a pic of that pivot bolt from a '99 FSM. If you loosen the tensioner bolt and the pump doesn't move, you will have to loosen the pivot bolt.
Old Nov 9, 2001 | 01:12 PM
theMax's Avatar
pic to help
pic of belts
Old Nov 9, 2001 | 03:20 PM
yourmove's Avatar
Yup! If it dosn't move and prolly won't, loosen the bolt on the back of pump. I had to! Also, you'll be kinda feeling your way around rather than seeing it! When you loosen the bolt, just give it a half turn. No need to remove.
Old Nov 10, 2001 | 05:50 AM
thw625's Avatar
Thanks for your help guys. I'll get in there and give it another shot.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
