Floor Jack Placement
Old Nov 13, 2001 | 02:07 PM
Help's Avatar
Where do you place a floor jack (front and rear) to raise the car? I'm guessing the differential for the front, but what about the rear?
Old Nov 13, 2001 | 02:22 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Floor Jack Placement
Read your owners manual.
If you want to raise a whole end at a time, use the crossmember under the engine for the front and the beam for the rear.
Old Nov 13, 2001 | 02:44 PM
Help's Avatar
Ummmm...not the jack that came with the car...a floor jack. I don't think the owner's manual covers this.
Old Nov 13, 2001 | 03:26 PM
SuDZ's Avatar
same place still. The reason they tell you is because they also tell you not to do any type of repair or work other than changing a tire with the one they give you.
SuDZ
Old Nov 13, 2001 | 04:27 PM
Kashoggio's Avatar
Dont use the jack up points for the factory jack. Any part of the car's frame will do just fine. The best jack up points are on the sides, a little bit behing the factory jack up points. You will notice a part of the frame with a small oval hole. This is the point.
Old Nov 15, 2001 | 05:42 PM
2DMax's Avatar
Look at the service manual, the biggie book.
You can jack the rear using the cross bar (U shapped thing).
The front, there is a nub in the center just front of the engine.
I would do a whole lot of work under a floor jack, use stands to do any real work.
Old Nov 15, 2001 | 08:11 PM
sinewave's Avatar
I STORONGLY DISAGREE!! Use jack stands ANYTIME you do work under the car, even if it is for 5 seconds. Ask yourself, is the 1 minute you save setting up the jack stands worth risking a 3000lb car sitting on our chest?
Old Nov 16, 2001 | 07:54 AM
Tai Mai Shu's Avatar
Sinewave, bravo! I totally agree and don't forget to chock the wheels. I didn't chock them one time and almost had a BMW crush me. At least if I was gonna get killed, it's a sweet ride . Now, if i'm going under, I double up the jacks as backup. I don't want the kids to get all my cheddar before I can spend it all...
Old Nov 16, 2001 | 01:45 PM
max7's Avatar
Be careful
A friend of mine lifted the rear end of his Maxima to install a trailer hinch for his jet ski. After lifting he rested the car on blocks. His mom backed the car into his which caused the car to fall. Even though the car was on wheels, it crushed him! He had broken hips, spine and legs. Couldn't walk for five months. To this day he uses crotches to get around! All because he didn't secure the car before working on it. After that I make sure the car will not fall on me because it's no joke!
Old Nov 16, 2001 | 03:18 PM
2DMax's Avatar
wow...mis-type.
I meant to say, use jack stands, and NOT a floor jack to do work.
Sorry....
NOT
Old Nov 16, 2001 | 03:48 PM
shane's Avatar
SO that little nub in the center can i put the floor jack there or is that a bad spot,from the way i take it it is a bad spot and what about the rear put the jack in the middle thanks
Old Nov 16, 2001 | 04:15 PM
sinewave's Avatar
That little nub is the perfect place for the jack. The rear axle does flex a little and if you have a RSB, you will have to put a spacer between the RSB and the axle.
Old Nov 17, 2001 | 01:52 PM
shane's Avatar
I have a floor jack and two jack stands,can i raise the back up in the middle and put the jack stands on the the beam more to the outside and then move the floor jack at the nub in the front and raise it up where all wheels are off the ground(so i can rotate my tires)thanks
Old Nov 19, 2007 | 10:46 AM
holymoly's Avatar
That little nub?
Any pictures?
Old Nov 19, 2007 | 10:49 AM
Greeny's Avatar
¯\(°_o)/¯
Old Nov 19, 2007 | 10:53 AM
holymoly's Avatar
Hey, I only have a 2.5 ton jack.....
Old Nov 19, 2007 | 11:38 AM
gen4maxima536's Avatar
that will work fine, your not going to be lifting the entire car at once. if your jacking up the front just put it under the cross member that goes under the engine (front to back)
Old Nov 19, 2007 | 11:42 AM
ROCKART's Avatar
wants an I35
"the little nub ?"
Old Nov 19, 2007 | 12:06 PM
SilverGLE's Avatar
I'm watching you, boy...
Wow, SEARCH!!! No one can stress that enough. If you search, there's another thread on this where irish44j posted pics of the nub for the front.
Old Nov 19, 2007 | 03:32 PM
NismoMax80's Avatar
SuPeRmOd
Originally Posted by holymoly
That little nub?
Any pictures?
BOOOOOOOOOOOOOO
Old Dec 15, 2007 | 12:00 PM
Flyer88's Avatar
Well said. Search Search Search.
Old Dec 15, 2007 | 12:29 PM
Nopike's Avatar
If your radiator core support is shot you may not want to use the nub.
Old Dec 31, 2007 | 10:05 AM
KenjiOta's Avatar
bump
Old Jan 1, 2008 | 03:45 PM
NismoMax80's Avatar
SuPeRmOd
Originally Posted by KenjiOta
bump
Old Jan 1, 2008 | 04:04 PM
matty's Avatar
Old Oct 23, 2011 | 09:02 AM
jh15's Avatar
The picture links going to be fixed on this website soon?
Every time I see a reference to where to jack my 2001 maxima, the pictures are not available.
Old Oct 23, 2011 | 12:33 PM
Mr. Blue Sky's Avatar
like mzmtg said, the cross member for the front, and the rear beam for the back. If your radiator support is shot, then get that fixed first, then use the crossmember to jack it up.
Old Oct 23, 2011 | 02:28 PM
jh15's Avatar
Thanks, but I was wondering where most of the pictures went.
For example, where to place the jack on the rear beam.... It is shaped like an upside down U and I was concerned with it twisting, as the floor jack pan does not hit the bottom two edges evenly. the bottom is recessed.
How do I know my radiator is at risk? the front crossmember looks ok, does it rust out and pop through to the radiator?.
Anyone find the vaporware Nissan pads?
Thanks.
Old Oct 24, 2011 | 03:55 AM
DennisMik's Avatar
Old Nov 26, 2011 | 04:46 PM
jgilbs's Avatar
Guys, first off I want to say - DONT EVER GET UNDER A CAR SUPPORTED BY ONLY A JACK - people have been killed this way!
It only takes a few extra seconds (and dollars) to put jackstands under the car, and lower the car onto them. After that, I usually go "cow tippin" (ie, I put my shoulder into the car and push) The car shouldnt budge. This gives you increased security/piece of mind that the car wont fall on you. I then usually slide the tires right behind the jack stands, just in case one were to fail, the car would fall on the tire/rim and not me.
I usually jack the car by the front "nub", and put jack stands where they specify in the FSM. As for the rear axle, I have jacked on it, but it always scares me that it flexes so much, and makes me wonder if I should put a spacer between the jack and axle to even out the load.
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
homewrecker
Sep 23, 2015 03:41 AM
