Failing HIDs...bulbs or ballasts?
Okay, so I know there have been a few threads about failing HIDs...but mine seems to be a bit different from others'. So here goes.
First off, let me state that I'm an idiot for investing in eBay bulbs and ballasts for my Max. At least they gave me a two year warranty. Let's see if they honor it.
Anyway. When I flip my fogs on, at first, both bulbs will come on like normal. However, after a few minutes, the driver's side bulb will start to slowly dim a little bit, and occasionally flicker. It's gotten to the point now where the bulb will gradually dim and just go out. But if I turn them off for about ten seconds, the ballast will re-ignite the bulb for another go-round of the same thing.
Also worth noting is that the bulb seems to stay on longer when the housing is cold. Once the housing warms up from the bulb being on, the light seems to fail faster.
In my opinion, it seems that it's the ballast failing because the bulb can be re-lit after a short period of being turned off, and it dies as though it's just kind of losing charge. But is it also possible that the bulb is over-heating and on the way out as a result? I know I've had this happen in the past with halogen bulbs...
Any suggestions? I'm going to try swapping bulbs when I get some spare time. I've only had these running for about 150 hours tops.
in all honesty i dont see what they hype is about getting HIDs from either ebay or someone on the forums...problems are bound to happen regardless. i purchased ebay HIDs as well as 'good' HIDs
granted ebay HIDs have initiated a problem that when i turn on my signal light it flickers. i havent had the 'good' HIDs long enough to start a problem, but my point is...they pretty much come from teh same place, whats the purpose of saying 'ebay = garbage HIDs'?
If you really want to find out if its the bulb or the ballast why don't you just swap the driver/passenger side bulbs. If the problem stays on the drivers side then its the ballast. If the problem is now on the passenger side then its the bulb.
i have a similar issue with an hid in my fogs 1 started 2 flicker then didnt work then did. so i just ordered a new hid ballist and bulbs in your case if they will not honor it then this is the website i used www.vvme.com and i paid 19.99 for 1 ballist and 25.99 for the h3c bulbs. i got that site from another member of a diff forum so hopefully i wont get screwed but good luck with ur issue man.
That could be your issue....probably not, but possibly. Regardless, its in your best interest to get a harness to power the ballast directly from the battery. A $20 harness cost a less to replace than a fried OEM harness.
Since then, I just haven't had time to do anything with them. I have yet to send the ballast back to the manufacturer...
The Frye
Sep 2, 2021 11:03 AM
03VQMAX
Nov 10, 2015 03:39 PM
alphakaoz
Sep 30, 2015 07:33 PM
Maxima30
Sep 7, 2015 06:13 PM
