fuel filter
Old Nov 6, 2000 | 04:28 PM
tclee's Avatar
how often must this be changed?
thanks
Old Nov 6, 2000 | 08:07 PM
Wizeguy's Avatar
I believe its 60,000 miles. Look in your owners manual to be sure.
Old Nov 7, 2000 | 05:43 AM
got rice?'s Avatar
better off w/ 3 yrs/36k miles. It's a cheap part and it's not <I>too</I> hard to replace. Clean fuel will extend the life of your injectors
Old Nov 7, 2000 | 10:53 AM
brandonj's Avatar
I change mine once a year, right after they stop making me buy oxygenated gas. I'm pretty sure that stuff fouls the filter at 3 times the normal rate.
Old Nov 7, 2000 | 11:05 AM
The_quorum's Avatar
Do you change it yourself??
If so, HOW DO YOU GET TO IT??? I can see the filter against the firewall, but can't for the life of me figure out how to get to it and remove it. I've done the sparkplugs, and PCV valve, but the fuel filter scares me. Any step by step instructions out there? I've got 71k on my '98...50k+ are mine since I bought it last year...I know for a fact that it hasn't been replaced before.
Old Nov 7, 2000 | 11:27 AM
brandonj's Avatar
There isn't any easy way to do it. I have bled every time. The only advice I have is to make sure there is no fuel pressure (can't remember how that's done right now) and push, don't pull, the hoses off the filter.
Old Nov 7, 2000 | 11:52 AM
DanNY's Avatar
Ad·min·is·tra·tor
gloves...wear some kind of gloves.
also long *** pliers helps a lot.
Dan
Old Nov 7, 2000 | 12:23 PM
DDD
Replace every 15to 20 kmiles
To release a fuel pressure:
1. Take away the fuel pump fuse
2. Start the engine and wait until it stops
3. Turn out ignition key and wait for 10 seconds
4. Try to start the engine again 2 times.
5. If it wouldn't start absolutely, there is no fuel pressure.
Be careful with gas in the engine compartment,
Good luck,
DDD
Old Nov 7, 2000 | 04:04 PM
got rice?'s Avatar
Re: Replace every 15to 20 kmiles
Good luck,
DDD
I also remove the fuel tank filler cap. Also WEAR GOGGLES or eye safety equipment!!!
The fuel lines can be tough to pull off. Just wiggle and turn the lines as you pull... they'll come off eventually.
Old Nov 7, 2000 | 04:15 PM
thanjp's Avatar
How much does a fuel filter run?
Old Nov 7, 2000 | 04:38 PM
got rice?'s Avatar
Re: How much does a fuel filter run?
Originally posted by thanjp
get a genuine Nissan one. Don't skimp out for a generic unit. They'll cost around $10-12
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
