Grinding noise when turning?
Old Dec 8, 2001 | 11:00 AM
Maximus97's Avatar
A few weeks ago I started to notice my car would make this metal on metal grinding noise when I would turn. It almost seemed like it was rubbing on something, but when I would check it out there was nothing in the way. Periodically it would would jerk hard to the side and I would have to really have to hang on so I wouldn't fly off the road. The dealership said it might be something wrong with the rack and pinion or possibly the steering column. I am hoping to get some feedback from you guys as to what the problem might be. Anyone ever had anything like this before?
Old Dec 8, 2001 | 05:07 PM
bullseye's Avatar
Re: Grinding noise when turning?
Does this happen when you turn both left and right, or only when you turn one way or the other? Is there a lot of grease "splashed" all up inside one of your front wheel wells? It sounds like you may have a bad CV joint. The boot cracks/breaks open, all the grease comes out, dirt and grit invade the joint, the joint begins to wear, you hear a grinding sound... You need to get that replaced ASAP. Oh, and nobody replaces those with new parts. Reconditioned axles/CV joints are used for the replacement as a rule. Rebuilt axles are usually just as good as new, and cost about 1/3 as much. Just make sure you get them from a reputable supplier. Good luck.
Old Dec 8, 2001 | 09:48 PM
LeoB's Avatar
not on a maxima but....
on my mom's 2000 Beetle a rear wheel grinding noise turned out to be an extremely unevenly and prematurely wearing break pad, resulting from a partially seized emergency brake cable. It only happened when the car was turning in one direction
Old Dec 8, 2001 | 11:21 PM
Eric L.'s Avatar
Originally posted by yo_its_ok
#1 CV Joint
#2 Upper strut mount, and spring top hat.
Yeah if it is a "clack clack clack" noise, I would check the CV joints. If it is a "gunk pop clang" noise, I would check to see that the upper strut perch is turning smoothly.
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
LtLeary
Sep 14, 2015 12:33 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
