Push to Start Ignition?
Old Jan 14, 2012 | 11:35 PM
VQPOWERGLE's Avatar
Does anyone know of a push to start button that still needs the key to be in the on position. All the ones i find have it so the key is deleted. a kill switch that can be hidden would be cool also.
let me know.
Old Jan 15, 2012 | 01:00 AM
mrjasonlyrics's Avatar
Just stay with your turn key man
Old Jan 15, 2012 | 12:12 PM
asand1's Avatar
Old Jan 15, 2012 | 02:46 PM
VQPOWERGLE's Avatar
haha. i was actually trying to add security to my car because of a couple car thefts in my area. it would look a little rice.
Old Jan 16, 2012 | 09:25 AM
asand1's Avatar
Toggle kill switches have been discussed in the 4th gen forums. No need for a start button, just interupt the fuel pump power.
Old Jan 16, 2012 | 04:21 PM
ThurzNite's Avatar
let me know.
I'm trying to understand what you're trying to do. If you're putting the key into the ignition, twisting the key, why not keep twisting and just start it right up?
If you want push-button start, why do you still want to use the key? Which goes back to the above paragraph --> if you're gonna use the key, just turn it on.
I'm just confused. Can you clarify what your intentions are?
Dr J
Old Jan 16, 2012 | 07:41 PM
VQPOWERGLE's Avatar
Well the main thing i want is to make it so that if someone gets in to my car they cant turn it on, and the push start that needs a key to be in the on position seems like a good idea. But a switch to the fuel pump sounds like it would be better.
Old Jan 18, 2012 | 02:46 AM
ThurzNite's Avatar
So a kill switch? Hold the switch/button, then turn the key?
Dr J
Old Jan 18, 2012 | 10:06 PM
VQPOWERGLE's Avatar
Dr J
Yeah. i want it set up so the car can't start without the switch on.
Old Jan 19, 2012 | 11:04 AM
ThurzNite's Avatar
I'd go with this:
Just remember to switch it every time. I'm lazy, I wouldn't go this route.
If you're good with alarms, you can wire up something with the ignition switch to supply power to the starter only when both switch is pressed and key is turned. That way you don't need to flip and switches when you park the car.
Dr J
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
rnb754
Sep 14, 2015 11:39 PM
trungg86
Sep 4, 2015 04:58 AM
