Got a rubber antenna...now problems...
Old Jan 22, 2002 | 02:07 PM
Vyrus's Avatar
Firstly, is there any page that tells me how to install this? Secondly, would any universal rubber antenna work or did I need to buy a specific one (because our antenna base is slanted). I just bought a $8 Advanced Auto Parts antenna, but it looks difficult to install and if it is I'll just give the antenna to my friend.
Thanks in advance,
Cyrus
Old Jan 22, 2002 | 02:45 PM
SuDZ's Avatar
Re: Got a rubber antenna...now problems...
Thanks in advance,
Cyrus
Does it replace the most or go on your roof like the VW ones?
SuDZ
Old Jan 22, 2002 | 03:03 PM
Mishmosh's Avatar
The only hard part is finding the cable that goes to the antenna. If you have the C&C package with the motorized antenna, the actual antenna assembly has a couple of wire harnesses. You just can't do away with the unit. Life is much easier if you are just replacing a stock fixed mast unit as the wire should be evident. In any case, aftermarket antennas can be mounted at almost any angle. There is a part that goes under the sheet metal that is adjustable and just needs to be fastened tight at whatever angle you want.
Old Jan 22, 2002 | 05:14 PM
Vyrus's Avatar
Re: Re: Got a rubber antenna...now problems...
Thanks but I just gave up and gave it too my friend. I couldn't find the connection wire (signal).
-Cyrus
Old Jan 22, 2002 | 07:11 PM
pocketrocket's Avatar
Re: Re: Re: Got a rubber antenna...now problems...
Bummer, hope your friend has better luck.
I was going to ask if the diversity antenna might be a problem (or do you have aftermarket already)?
shilov
Feb 19, 2024 09:40 PM
vingodine
45
May 21, 2016 12:46 PM
Maxboy23
Sep 9, 2015 10:37 AM
beerman1378
Sep 8, 2015 02:19 PM
maximusrising
Sep 4, 2015 06:31 PM
