problem with throwout bearing and clutch fork
Old Jan 24, 2002 | 09:21 AM
SterlingMistMax's Avatar
ok im replacing my clutch.. when i got the tranny out .. i took the throw out bearing out but while doing this the whole clutch fork came loose and the clip flew out
anyone have this happen ? im pretty sure i put the clip back in right but it doesnt seems to be returning the throw out bearing against the wall of the tranny like it should...im thinking i should get a new clip...any ideas?
Old Jan 24, 2002 | 09:43 AM
Jeff92se's Avatar
I'm needing a caw
The clip is there to hold the shift fork in the tranny. This is the Y fork that is pushed by the slave cylinder correct?? The clip just holds the fork onto the "ball" that's inside the transmission housing. But you should make sure you have the bearing the correct way and not facing the wrong way. Make sure you use the proper type of grease on the shaft the TO bearing rides on also.
Old Jan 24, 2002 | 10:15 AM
Yes the Y fork.. so all it does is hold the Y in place? should the Throw out bearing return all the way to the wall of the tranny when its released?
And im sure i have the T.O.B the right way
Old Jan 24, 2002 | 10:19 AM
Jeff92se's Avatar
I'm needing a caw
Maybe a little but again, it's not really the clip's function.
Old Jan 24, 2002 | 10:35 AM
I just wanna make sure i got it right before i put everything back together .. it would suck to have to take everything apart again
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
londonflu
40
Sep 25, 2015 09:11 AM
ballerchris510
Sep 11, 2015 05:29 PM
jfl330
Sep 4, 2015 01:44 PM
