Can i do a engine swap from a 6th gen nissan maxima 04 to a gen 7th nissan maxima 12?
Old Aug 29, 2024 | 09:17 PM
Jawaun103's Avatar
So i recently bought a new engine but im just now realizing its a 6th gen engine but i have the 7th gen maxima will it be able to fit in the 7th gen ? If so what parts will be need swapped out?
Old Aug 30, 2024 | 06:16 AM
RA030726's Avatar
I'm nutty for Nissans
Not going to work.
Old Oct 8, 2024 | 02:44 PM
commaxi's Avatar
Yes, you can do an engine swap between a 6th generation 2004 Nissan Maxima and a 7th generation 2012 Nissan Maxima,
I HOPE THAT MY ANSWER is helpful and not too late
Old Oct 8, 2024 | 03:10 PM
2002SEMT's Avatar
It's a bad idea. A 6th gen engine has oil consumption problems and timing chain issues.
Old Oct 8, 2024 | 03:21 PM
slvr2KSE5's Avatar
sadly that is not helpful because it wont work.
cam trigger wheels are wrong and pinned wrong. youll have to do the opposite of the 7th to 5th gen swap. theres no EVT control so that will **** off the 7th gen ECM even if you could get past the trigger wheel issue.
Old Oct 28, 2024 | 06:32 AM
95maxrider's Avatar
Lightly modded
The motor from a 6th gen is vastly inferior to the engine from a 7th gen. The amount of work you would have to do to make it run is not worth it. Either return the engine or sell it to someone else and buy the right engine.
Old Nov 13, 2024 | 09:19 AM
commaxi's Avatar
It is possible that the 6th generation engine can be fitted to the 7th generation Maxima, but some adjustments will likely be required. Parts that will need to be replaced or adapted include engine mounts, exhaust system components, electronic system components (ECU, wiring), and some accessory components such as the alternator or fuel pump.
Old Nov 13, 2024 | 09:21 AM
slvr2KSE5's Avatar
oh look...its a bot.
hot04
Sep 18, 2015 06:14 AM
Chris Alexander
20
Jul 22, 2013 06:45 AM
canIlive
Dec 23, 2009 09:35 PM
BLCKMAX
37
Aug 13, 2009 06:20 PM
1SICKLEX
Jul 19, 2009 05:17 PM
